Toshiba's 7200 rpm 3.5-inch HDD series is optimized for use in power-friendly consumer and commercial desktop computers, gaming PCs and external HDDs. The DT01ACA200 offers large capacity and uses advanced format and leverages a best-in-class power management technology. In addition, this desktop drive provides up to 16% idle power savings over the previous model. The 6 Gbps SATA interface drives deliver 7200 rpm performance. The HDD is designed to allow manufacturers to leverage the benefits of the latest components and operating systems to deliver high-performance, high-capacity, power-efficient systems.
2TB capacity
7200 RPM performance
For use in consumer and commercial computers
6 Gb/s SATA Interface
Halogen-free design
Specification
Capacity: 2TB
Form factor: 3.5 inch
Interface type: Serial ATA
Rotational speed: 7,200 rpm
Supported interface standards: ATA-8 Serial ATA 3.0
S.M.A.R.T.: The SMART command set is supported.
Transfer rate - SATA (Host) max.: 6.0 Gbit/s
Buffer size: 64 MByte
Physical
Bytes/sector (Host): 512
Bytes/sector (Disk): 4096 kByte
Access
Single track seek time (read): 0.5 ms
Single track seek time (write): 0.6 ms
Reliability
Load/Unload: 300,000 Times
Non-recoverable error rate: 1 error per 1014 read
Power Consumption
Read (Random): 6.4W
Write (Random): 6.4w
Idle: 5.2w
Stand-by: 1.0w
Sleep: 1.0w
Mechanical Specifications
Drive width: 101.6 mm
Drive height: 26.1 mm
Drive depth: 147 mm
Weight (max.): 0.680 kg
Temperature, Vibration & Shock
Operating Temperature: From 0 °C to 60 °C
Non-operating Temperature: From -40 °C to 70 °C
Operating Vibration: 0.67 G, with 5 - 500 Hz
Non-operating (Maximum) Vibration: 1.04 G, with 2 - 200 Hz
Operating Shock: 70 G, with 2 ms half sine wave
Non-operating shock: 300 G, with 2 ms half sine wave
Support
2 Year Manufacturer Warranty
Robust storage capacity
Equipped with a 2 TB capacity, this hard drive provides ample space for storing large files, high-resolution images, and extensive software libraries, making it an ideal solution for both personal and professional use. -
Enhanced durability
Designed to withstand the rigors of daily use, this hard drive features a shock tolerance of 70 g @ 2 ms half-sine pulse when operating and 300 g @ 2 ms half-sine pulse in storage, ensuring your data remains safe even in the event of physical impacts. -
Efficient performance
With a data transfer rate of 600 MBps and a spindle speed of 7200 rpm, this hard drive ensures quick and efficient access to your data, significantly reducing waiting times for file transfers and system boot-ups.
- Toshiba DT01ACA200 - hard drive - 2 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 2 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 64 MB
- Spindle Speed
- 7200 rpm
- Halogen Free, Advanced Format technology, S.M.A.R.T.
- 10.16 cm x 14.7 cm x 2.61 cm
- 680 g
- Microsoft Certification
- Compatible with Windows 7
- Capacity
- 2 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- Bytes per Sector
- 4096
- 10.16 cm
- 14.7 cm
- 2.61 cm
- 680 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Spindle Speed
- 7200 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 6.4 Watt (active) , 1 Watt (idle)
- RoHS
- 0 °C
- 60 °C
- Shock Tolerance
- 70 g @ 2ms half-sine pulse (operating) / 300 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.67 g @ 5-500 Hz (operating) / 1.04 g @ 2-200 Hz (non-operating)
- Sound Emission
- 27 dB
