Toshiba 2TB SATA 6GB/s 64MB 7200RPM 3.5" Hard Drive
Quicklinx: 9126WS00 Mfr#: DT01ACA200
Form Factor: 3.5 x 1/3H
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 2TB
Spin Speed (rpm): 7200rpm
Hurry, only 2 left in stock!
£40.65 ex VAT
£48.78 inc VAT
Toshiba's 7200 rpm 3.5-inch HDD series is optimized for use in power-friendly consumer and commercial desktop computers, gaming PCs and external HDDs. The DT01ACA200 offers large capacity and uses advanced format and leverages a best-in-class power management technology. In addition, this desktop drive provides up to 16% idle power savings over the previous model. The 6 Gbps SATA interface drives deliver 7200 rpm performance. The HDD is designed to allow manufacturers to leverage the benefits of the latest components and operating systems to deliver high-performance, high-capacity, power-efficient systems.
2TB capacity
7200 RPM performance
For use in consumer and commercial computers
6 Gb/s SATA Interface
Halogen-free design
Specification
Capacity: 2TB
Form factor: 3.5 inch
Interface type: Serial ATA
Rotational speed: 7,200 rpm
Supported interface standards: ATA-8 Serial ATA 3.0
S.M.A.R.T.: The SMART command set is supported.
Transfer rate - SATA (Host) max.: 6.0 Gbit/s
Buffer size: 64 MByte
Physical
Bytes/sector (Host): 512
Bytes/sector (Disk): 4096 kByte
Access
Single track seek time (read): 0.5 ms
Single track seek time (write): 0.6 ms
Reliability
Load/Unload: 300,000 Times
Non-recoverable error rate: 1 error per 1014 read
Power Consumption
Read (Random): 6.4W
Write (Random): 6.4w
Idle: 5.2w
Stand-by: 1.0w
Sleep: 1.0w
Mechanical Specifications
Drive width: 101.6 mm
Drive height: 26.1 mm
Drive depth: 147 mm
Weight (max.): 0.680 kg
Temperature, Vibration & Shock
Operating Temperature: From 0 °C to 60 °C
Non-operating Temperature: From -40 °C to 70 °C
Operating Vibration: 0.67 G, with 5 - 500 Hz
Non-operating (Maximum) Vibration: 1.04 G, with 2 - 200 Hz
Operating Shock: 70 G, with 2 ms half sine wave
Non-operating shock: 300 G, with 2 ms half sine wave
Support
2 Year Manufacturer Warranty
  • Robust storage capacity
    Equipped with a 2 TB capacity, this hard drive provides ample space for storing large files, high-resolution images, and extensive software libraries, making it an ideal solution for both personal and professional use.
  • Enhanced durability
    Designed to withstand the rigors of daily use, this hard drive features a shock tolerance of 70 g @ 2 ms half-sine pulse when operating and 300 g @ 2 ms half-sine pulse in storage, ensuring your data remains safe even in the event of physical impacts.
  • Efficient performance
    With a data transfer rate of 600 MBps and a spindle speed of 7200 rpm, this hard drive ensures quick and efficient access to your data, significantly reducing waiting times for file transfers and system boot-ups.
Toshiba DT01ACA200 - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Halogen Free, Advanced Format technology, S.M.A.R.T.
10.16 cm x 14.7 cm x 2.61 cm
680 g
Microsoft Certification
Compatible with Windows 7
2 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
Bytes per Sector
4096
10.16 cm
14.7 cm
2.61 cm
680 g
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
6.4 Watt (active) , 1 Watt (idle)
RoHS
60 °C
Shock Tolerance
70 g @ 2ms half-sine pulse (operating) / 300 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.67 g @ 5-500 Hz (operating) / 1.04 g @ 2-200 Hz (non-operating)
Sound Emission
27 dB
9126 StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £67.34
Type: Hard drive
Capacity: 2TB
Brand: Toshiba
Stock Status: While stocks last
Stock Status: Clearance
