Toshiba 2TB Canvio Basics USB 3.0 2.5" Portable Hard Drive
Quicklinx: 9QTDWS00 Mfr#: HDTB320EK3CA
Toshiba's Canvio Basics for the PC requires only a single step to start saving and transporting important files, plug it in. With no software necessary to install, the Canvio Basics portable hard drive offers a hassle-free, high capacity storage solution right out of the box.
A sleek solution with plenty of storage capacity for the growing amount of digital content, from photos and videos to music and documents, the Canvio Basics offers an intelligent combination of data protection, portability, and simplicity. The one plug ease-of-use is complemented by the drive's stylish design, courtesy of a glossy finish and soft, rounded edges. Despite its light weight design and diminutive size, the Canvio Basics can add peace of mind by keeping files safe with its internal shock sensor and Ramp Loading technology.
Beyond its technical capabilities, the practicality of the Canvio Basics portable hard drive is evident in the drive's pocket-sized form factor which not only makes it easy to carry but also conforms to Toshiba's environmental efforts to reduce materials used in production. In addition, the Canvio Basics' packaging is made from 100 percent recyclable materials.
  • Interface USB 3.0 (USB 2.0 compatible)
  • Max. transfer rate ~ 5.0 Gbs
  • Enclosure Matt casing
  • Color Black
  • Capacity 2TB
  • File system NTFS (MS Windows) *The drive can be re-formatted to HFS+ file system for full Mac compatibility.
  • Power USB bus power (max. 900mA)
  • Dimensions 119 x 79 x 20.5 (mm)
  • Weight max. 230 g
  • System requirements Windows 8.1 / Windows 8 / Windows® 7
  • CPU with 750 MHz or faster, 10MB system hard disk space, 256MB system memory, one free port of USB 3.0 or USB 2.0
  • Box content Canvio Basics, USB 3.0 micro-B cable, Quick Start Guide, User's Manual (pre-installed on the hard drive), Warranty Leaflet
  • Rapid transfer speeds
    Experience swift data transfer with the Toshiba Canvio Basics, boasting a speed of 500 MB/s thanks to its USB 3.0 interface. This ensures quick and efficient file transfers, making it suitable for busy professionals and multimedia enthusiasts.
  • Generous storage capacity
    With a 2 TB capacity, the Toshiba Canvio Basics offers ample space for your collection of documents, photos, movies, and music. Its portable design paired with a large storage capacity makes it perfect for users who need their data accessible while on-the-go.
  • Easy compatibility
    Designed for seamless integration, the Toshiba Canvio Basics is NTFS formatted and compatible with PC, ensuring a Plug-and-Play experience without the need for additional drivers or software installation. Its USB 3.0 interface provides universal connectivity and backward compatibility with USB 2.0 devices.
Toshiba Canvio Basics - hard drive - 2 TB - USB 3.0
Hard drive - external (portable)
2 TB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
NTFS formatted
Power Source
USB bus
Enclosure Colour
79 mm x 119 mm x 20.5 mm
230 g
2 TB
2.5"
USB 3.0
NTFS formatted
79 mm
119 mm
20.5 mm
230 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Data Transfer Rate Details
USB 3.0: 500 MB/s
Expansion & Connectivity
1 x USB 3.0
Compatible Bay
2.5"
Power Source
USB bus
Microsoft Windows 7 / Windows 8, Windows 8.1
1 x USB cable - external
Enclosure Colour
