The Canvio Advance portable hard drive allows creators to do what they do best - anywhere their lives take them - offering high storage capacity, 24/7 access to your stored content and the time-tested reliable performance they need.
Whenever and wherever creativity strikes, Canvio Advance offers the space to create. The Toshiba Canvio Advance provides a lot of storage so you can store thousands of pictures, videos, music, or a variety of large files on a small 2.5" portable drive.
The Toshiba Canvio Advance features a minimalist design as well as clean edges, a sleek, high-gloss surface, and color options to inspire you - it's your life, your style, your speed.
Keep your files safe and secure with features such as password protection and scheduled backup. Work at the speed of inspiration with the lightning fast transfer speeds of Canvio Advance. With USB 3.0 you'll be able to transfer and backup files on the go while powering the drive through your laptop's USB connection.
These durable external hard drives are built to Toshiba's world-class quality standards. Access all of your stored content 24/7 easily from the Canvio Advance hard drive.
- Toshiba Canvio Advance - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 2 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- NTFS formatted
- Power Source
- USB bus
- Enclosure Colour
- Glossy piano blue
- 7.8 cm x 10.9 cm x 1.4 cm
- 149 g
- 2-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.0
- NTFS formatted
- 7.8 cm
- 10.9 cm
- 1.4 cm
- 149 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- OS Required
- Microsoft Windows 7 / 8.1 / 10
- Cables Included
- 1 x USB 3.0 cable - USB Type A to micro-B - external
- Enclosure Colour
- Glossy piano blue
- Shipping Width
- 12.8 cm
- Shipping Depth
- 4 cm
- Shipping Height
- 14 cm
- Shipping Weight
- 250 g
- Limited warranty - 2 years
