Toshiba 26DV713B 26" HD LCD
Toshiba DV Series Television
Quicklinx: 6P8ZWS00 Mfr#: 26DV713B
  • FREEVIEW
  • HD ready
  • DVB-T
Ideal for when space is limited, the DV series is a LCD/DVD player combi offering the reassurance of Toshiba quality combined with highly affordable prices. With a 66cm (26") screen and stylish gloss black design the DV offers a HD ready resolution and HDMI connectivity. The DV features a built-in DVD player making it ideal for small spaces whilst built-in Freeview provides access to 50 digital TV channels and 24 radio stations without subscription. PC input allows you to connect your PC and use the DV as a PC monitor.
  • HD ready
    Supports 720p resolution content, the standard of most HD broadcast. An HD ready TV will be able to display an HD feed from any HD source.
  • Freeview
    Built-in Freeview is the easiest way to enjoy digital for free. There are to up to 50 digital TV channels and 24 radio stations.
  • Built-in DVD player
    The built-in slot loading DVD player with easy to access operation buttons is a convenient all-in-one space saving design. You can also playback DivX movie downloads, JPEG photos and MP3 music files.
  • HDMI
    HDMI connectivity makes it easy to connect to Blu-ray players, HD games consoles and other devices.
  • PC input
    PC input allows quick and easy connection to your laptop or PC so the TV can double as a PC monitor.
  • USB
    USB connectivity provides an easy way to playback your music and photos directly via your TV.
Toshiba 26DV713B DV Series - 26" LCD TV - HD
LCD TV with built-in DVD player
Diagonal Class
26"
Resolution
1366 x 768
Display Format
720p
Video Interface
Component, composite, HDMI, S-Video, SCART
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-T
Analogue TV Tuner
PAL, SECAM
Sound Output Mode
Stereo
Speaker System
2 speakers
Stereo Reception System
NICAM
DVD
DVD player - built-in
USB
Remote control
66.6 cm x 9.6 cm x 45 cm
7.4 kg
LCD TV
Diagonal Class
26"
Combined With
Built-in DVD player
Series
DV Series
TV Tuner
TV Tuner Presence
Sensors
Ambient light sensor (ALS)
Video Interface
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
Modes
Picture frame mode
Dimensions
Without stand
66.6 cm
9.6 cm
45 cm
7.4 kg
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Dynamic Contrast Ratio
30000:1
Brightness
450 cd/m²
Widescreen Modes
Conventional 4:3
Viewing Angle
176 degrees
Response Time
8.5 ms
Comb Filter
3D digital
Colour Temperature Control
3D Color Management, MPEG Noise Reduction
DVD
Media Type
CD-R, CD-RW, SVCD, DVD-R, DVD+RW, DVD-RW, DVD+R, DVD, CD, Video CD
DivX capable, JPEG photo playback, MP3 playback
TV Tuner
Analogue TV Tuner
PAL, SECAM
NICAM
Digital TV Tuner
Digital TV Tuner
DVB-T
Digital TV Service
FREEVIEW
Video Features
Analogue Video Input Signals
PAL
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Output Power / Total
6 Watt
Speakers
2 x main channel speaker - 3 Watt
Network & Internet Multimedia
Supported Consumer Electronics Control (CEC)
REGZA LINK
Connector Type
2 x HDMI input , SCART , S-Video input , Component video input , Composite video input , VGA input , USB , Headphones , Digital audio output (optical)
Expansion Slots
1 x Common Interface slot
Dimensions & Weight Details
Panel with stand - 66.6 cm x 26 cm x 49 cm x 8.8 kg , Panel without stand - 66.6 cm x 9.6 cm x 45 cm x 7.4 kg
