Ideal for when space is limited, the DV series is a LCD/DVD player combi offering the reassurance of Toshiba quality combined with highly affordable prices. With a 66cm (26") screen and stylish gloss black design the DV offers a HD ready resolution and HDMI connectivity. The DV features a built-in DVD player making it ideal for small spaces whilst built-in Freeview provides access to 50 digital TV channels and 24 radio stations without subscription. PC input allows you to connect your PC and use the DV as a PC monitor.
HD ready
Supports 720p resolution content, the standard of most HD broadcast. An HD ready TV will be able to display an HD feed from any HD source. -
Freeview
Built-in Freeview is the easiest way to enjoy digital for free. There are to up to 50 digital TV channels and 24 radio stations. -
Built-in DVD player
The built-in slot loading DVD player with easy to access operation buttons is a convenient all-in-one space saving design. You can also playback DivX movie downloads, JPEG photos and MP3 music files. -
HDMI
HDMI connectivity makes it easy to connect to Blu-ray players, HD games consoles and other devices. -
PC input
PC input allows quick and easy connection to your laptop or PC so the TV can double as a PC monitor. -
USB
USB connectivity provides an easy way to playback your music and photos directly via your TV.
- Toshiba 26DV713B DV Series - 26" LCD TV - HD
- Product Type
- LCD TV with built-in DVD player
- Diagonal Class
- 26"
- Resolution
- 1366 x 768
- Display Format
- 720p
- Video Interface
- Component, composite, HDMI, S-Video, SCART
- HDMI Ports Qty
- 2 ports
- PC Interface
- VGA (HD-15)
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-T
- Analogue TV Tuner
- PAL, SECAM
- Sound Output Mode
- Stereo
- Speaker System
- 2 speakers
- Stereo Reception System
- NICAM
- DVD
- DVD player - built-in
- USB
- Included Accessories
- Remote control
- Dimensions (WxDxH) - without stand
- 66.6 cm x 9.6 cm x 45 cm
- 7.4 kg
- Product Type
- LCD TV
- Diagonal Class
- 26"
- Combined With
- Built-in DVD player
- Series
- DV Series
- TV Tuner
- TV Tuner Presence
- Sensors
- Ambient light sensor (ALS)
- Video Interface
- HDMI Ports Qty
- 2 ports
- PC Interface
- VGA (HD-15)
- Modes
- Picture frame mode
- Dimensions
- Without stand
- 66.6 cm
- 9.6 cm
- 45 cm
- 7.4 kg
Display
- Resolution
- 1366 x 768
- Display Format
- 720p
- 16:9
- Dynamic Contrast Ratio
- 30000:1
- Brightness
- 450 cd/m²
- Widescreen Modes
- Conventional 4:3
- Viewing Angle
- 176 degrees
- Response Time
- 8.5 ms
- Comb Filter
- 3D digital
- Colour Temperature Control
- 3D Color Management, MPEG Noise Reduction
DVD
- Media Type
- CD-R, CD-RW, SVCD, DVD-R, DVD+RW, DVD-RW, DVD+R, DVD, CD, Video CD
- DivX capable, JPEG photo playback, MP3 playback
TV Tuner
- Analogue TV Tuner
- PAL, SECAM
- NICAM
Digital TV Tuner
- Digital TV Tuner
- DVB-T
- Digital TV Service
- FREEVIEW
Video Features
- Analogue Video Input Signals
- PAL
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Sound Output Mode
- Stereo
- Speaker System
- 2 speakers
- Output Power / Total
- 6 Watt
- Speakers
- 2 x main channel speaker - 3 Watt
Network & Internet Multimedia
- Supported Consumer Electronics Control (CEC)
- REGZA LINK
- Connector Type
- 2 x HDMI input , SCART , S-Video input , Component video input , Composite video input , VGA input , USB , Headphones , Digital audio output (optical)
- Expansion Slots
- 1 x Common Interface slot
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel with stand - 66.6 cm x 26 cm x 49 cm x 8.8 kg , Panel without stand - 66.6 cm x 9.6 cm x 45 cm x 7.4 kg
