Toshiba 22D1333B 22 Inch Full HD 1080p LED TV/DVD Combi
Quicklinx: 8ZZPWS00 Mfr#: 22D1333B
  • 1080p
  • DVB-T
Perfect for small rooms or when space is limited, the 22" D1333 delivers Full High Definition image quality with the convenience of a built-in DVD player. LED technology means you'll enjoy amazing colour, brightness and clarity, delivered in stylish slim frame design. With the reassurance of Toshiba quality, the 22" D1 Series also includes built-in Freeview digital TV access, for subscription-free access to 50 digital TV channels and 24 radio stations without the need for an additional set top box. An 8 day electronic programme guide helps you plan your week's viewing, plus enjoy video, photo and audio playback via USB, Dolby Digital Plus audio and the convenience of HDMI connectivity and PC input that make it easy to connect to other digital entertainment devices in your home.
Built-in DVD Player
The ease of DVD entertainment without the hassle of a separate unit, the built-in DVD player provides a convenient, all-in-one, space saving entertainment hub for any room. Cut down on wires, cables and remote controls - simply insert your favourite films into the DVD player built into the 22" D1 Series LED TV and enjoy. Not only can you experience DVD-quality entertainment, you can also playback JPEG photos and MP3 music files, freeing your favourite content to be enjoyed on a larger screen.
DVD player
Space saver - simply insert DVDs directly into the Toshiba 22" D1 Series LED TVs and enjoy your favourite movies and TV box sets.
Full High Definition 1080p
The 22" D1 Series supports Full High Definition 1080p resolution content. Offering outstanding picture quality and lifelike image reproduction, your films and programmes will appear crisper and more detailed, allowing you to take your enjoyment to the next level. Ideal for sports, movie and documentary enthusiasts who want to experience the most from their entertainment, this Full HD TV will be able to display HD images from any HD source.
LED Technology
The 22" D1 Series also includes an advanced backlighting system that guarantees new levels of picture clarity by constantly adapting to the images on the screen. Colours are made more vibrant and contrast between light and dark is more pronounced, providing dramatically improved performance, whilst overall energy consumption and the thickness of the TV is also reduced. Response times are also much quicker than conventional CCFL LCD TVs, so fast moving image quality is improved.
Built-in Freeview Digital TV
Built-in Freeview is the easiest way to enjoy digital TV for free. There are to up to 50 digital TV channels and 24 radio stations. No subscription, no contract, no fuss - with a Freeview tuner you can be sure your TV is compatible with the digital switchover, allowing you to enjoy your favourite shows in digital quality for years to come.
AMR100 Picture Processing
Toshiba's AMR100 picture processing technology provides vivid images and ultra-smooth moving picture quality. Motion blur is drastically reduced in fast moving pictures, such as action sequences or sports, delivering more defined movement on screen.
USB Playback - View Images, Video and Audio
The built-in USB connectivity provides an easy way to playback your compatible videos, music and photos directly via your TV. Simply plug a compatible USB drive into one of the two USB ports on the TV and select the file you want to play.
8 Day Electronic Programme Guide
Never miss your favourite shows again - the 22" D1 Series includes a built-in electronic programme guide showing the digital TV programmes scheduled over the next 8 days. Plan your viewing in advance or easily browse the full range of Freeview channels - no listings magazines needed.
HDMI and PC Inputs
The included HDMI input makes it easy to connect to a Blu-ray, DVD player, gaming console or many other devices via a single cable, allowing you to easily enjoy the best HD content available. Need a larger screen for your laptop? The PC input allows connection to a laptop or PC so your TV doubles as a PC monitor.
Wall Mountable
This TV is ready to mount on your wall. A wall mount with fitting dimensions of 75 x 75 will be compatible with this TV.
Dolby Digital Plus
Dolby Digital Plus, or Enhanced AC-3 (E-AC-3), is an advanced surround sound audio codec designed specifically for evolving media, ensuring that you get the renowned Dolby cinema experience from all your entertainment. Dolby Digital Plus is based on core Dolby Digital technologies, the established standard for cinema, broadcast, and home theatre surround sound.
Dolby Digital Plus Benefits:
Up to 7.1 discrete channels of clear, high-fidelity surround sound
Ideal audio codec match for HD video codecs
Dolby cinematic audio experience for content across all media
Full 5.1-channel interactive experience for Blu-ray BonusView and BD-Live
Full 7.1-channel support for primary Blu-ray soundtracks
Easily converted to Dolby Digital, enabling compatible playback through current Dolby Digital equipped systems
  • Built-in DVD player
    The built-in DVD player provides a convenient, all-in-one, space saving entertainment hub for any room. You can also playback JPEG photos and MP3 music files.
  • High definition image quality
    It supports high definition 720p/1080i resolution for stunning picture quality. A HD ready TV will allow you to display high definition content from various HD devices and services available today.
  • AMR100 picture processing
  • LED technology
    An advanced backlighting system that guarantees some levels of picture clarity by constantly adapting to the images on the screen. Colors are made more vibrant and contrast between light and dark is more pronounced, providing dramatically improved performance, whilst overall energy consumption and the thickness of the TV is also reduced.
Toshiba 22D1333B D1 Series - 22" LED-backlit LCD TV
LED-backlit LCD TV with built-in DVD player
Diagonal Class
22"
Resolution
1920 x 1080
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p, 720i
Frame Rate & Enhancement Technology
50 Hz Active Motion Rate
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T
Analogue TV Tuner
PAL, SECAM
Speaker System
2 speakers
Stereo Reception System
NICAM
DVD
DVD player
USB
2 ports
Toshiba RC1910 remote control, 2 AAA batteries
Voltage
AC 230V (50 Hz)
Energy Class
Class A
65 Watt
Power Consumption (On mode)
38 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
56 kWh
51.8 cm x 16.3 cm x 35.8 cm
9.5 kg
LED-backlit LCD TV
Energy Class
Class A
65 Watt
38 W
56 kWh
Diagonal Class
22"
Combined With
Built-in DVD player
Series
D1 Series
TV Tuner
TV Tuner Presence
Video Interface
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
Modes
Game mode
Timer Functions
Sleep
Dimensions
With stand
51.8 cm
16.3 cm
35.8 cm
9.5 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Image Contrast Ratio
1000:1
Brightness
250 cd/m²
Viewing Angle
130 degrees
Response Time
5 ms
Comb Filter
3D digital
Colour Temperature Control
Audio Description (AD), Automatic Format Detection (AFD), Digital Noise Reduction (DNR), MPEG Noise Reduction
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 100 mm
DVD
DVD player
JPEG photo playback, MP3 playback
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface Plus (CI+) slot
Reception System
SECAM-D, SECAM-B, SECAM-K, PAL-B, SECAM-G, PAL-G, PAL-I, PAL-D, SECAM-L, PAL-K
NICAM
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T
HDTV Tuner
MPEG Profiles and Levels
MPEG4 AVC/H.264
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM
Input Video Formats
Teletext
Teletext Memory
1000 pages
Digital EPG
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Remote Control Model
Toshiba RC1910
Audio System
Digital Audio Format
Dolby Digital Plus output
Surround Mode
Speaker System
2 speakers
Output Power / Total
12 Watt
Virtual surround sound, Dolby Digital Plus
Speakers
2 x main channel speaker - 6 Watt
Connector Type
Headphones , Digital audio output (coaxial) , 2 x USB , VGA input , SCART , HDMI - rear
2 AAA batteries
Component video adapter , Composite adapter
Power supply
Input Voltage
AC 230V (50 Hz)
0.5 Watt
Auto On/Off
Dimensions & Weight Details
Panel without stand - 51.8 cm x 4.6 cm x 32.1 cm x 5.85 kg , Panel with stand - 51.8 cm x 16.3 cm x 35.8 cm x 9.5 kg
Width (Shipping)
66 cm
Depth (Shipping)
11 cm
Height (Shipping)
39 cm
Weight (Shipping)
12.5 kg
