Toshiba 1TB Stor.E Partner USB 3.0 2.5" Portable Hard Drive Black
Quicklinx: 8NPSWS00 Mfr#: PA4282E-1HJ0
STOR.E PARTNER is a stylish external drive for storing your data! Subtle metallic reflections and engraved dots accent its fresh look in a robust, rubber-textured casing. Transfer media files in a snap from your laptop via SuperSpeed USB 3.0. The STOR.E PARTNER drive is large enough to house huge digital media libraries.
Key Features
  • Capacity - 1TB
  • Interface Type - SuperSpeed USB 3.0
  • Data Transfer Rate - 5.0 Gbps (SuperSpeed USB)
  • Power Source - USB bus
Style
The design of Toshiba's STOR.E PARTNER perfectly matches the Toshiba NB500 netbook series' young and fresh looks with subtle metallic reflections, engraved dots and rubber texture.
High Capacity For Even Large Media Libraries
The storage capacity of the external hard disk drives of 1TB is large enough to house huge digital media libraries. Via its USB 3.0 port, STOR.E PARTNER transfers large media files quickly to connected USB 3.0 laptop.
Back-Up Software On-Board
The pre-loaded Nero BackItUp & Burn Essentials software comfortably and reliably backs up and restores files and folders and recovers damaged or accidentally deleted data.
Toshiba StorE PARTNER - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
2.5"
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Ramp Load
Power Source
USB bus
Enclosure Colour
8.3 cm x 11.9 cm x 1.7 cm
195 g
Satellite S70-B-10F
1 TB
2.5"
USB 3.0
Ramp Load
8.3 cm
11.9 cm
1.7 cm
195 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Compatible Bay
2.5"
Power Source
USB bus
Software Included
Microsoft Windows 7
1 x USB 3.0 cable - external
Plug and Play
Enclosure Colour
Toshiba Satellite S70-B-10F
Resources
The following resources are available for the Toshiba 1TB Stor.E Partner USB 3.0 2.5" Portable Hard Drive Black
