Toshiba 1TB StorE Basics 2.5 inch USB 3.0 External Hard Drive Black
Quickly transfer files with SuperSpeed USB 3.0 and store up to 1TB of data on STOR. E BASICS external drives. Easy to use and backward compatible with USB 2.0, STOR. E BASICS external drives are ready to use with no software installation required.
Key Features
- Capacity - 1TB
- Interface Type - SuperSpeed USB 3.0
- Data Transfer Rate - 5.0 Gbps (SuperSpeed USB)
- Power Source - USB bus
- Type - Hard drive - external
The Toshiba STOR.E Basics 2.5 Inch 1TB external hard drive makes super speed storage simple. Receive high speed storage via the USB 3.0 port, allowing you to store your data with super speed. It's backwards compatible with USB 2.0 and is easy to use for everybody. An easy plug and play operation makes it ready to use with Microsoft Windows with no software installation required. Enjoy high capacity storage of up to 1TB in a conveniently .compact casing
Box Contents
- STOR.E BASICS
- USB 3.0 cable ("A" to Micro "B")
- Quick Start Guide
- Warranty Leaflet pre-installed User´s Manual
System requirements
- Microsoft® Windows® XP/Vista/Windows® 7
- CPU with 750 MHz or faster
- 10MB system hard disk space
- 256MB system memory
- one free port of USB 3.0 or USB 2.0
- Toshiba StorE BASICS - hard drive - 1 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- 5.0 Gbps (USB 3.0)
- Ramp Load
- Power Source
- USB bus
- Enclosure Colour
- Matte black
- 7.9 cm x 11.9 cm x 1.7 cm
- 180 g
- Designed For
- Dynabook Toshiba Portégé R830, R930, Z830, Z930; Toshiba Satellite Pro C850, L830, L850, L870; Toshiba Tecra A11, R840, R940, R950; Toshiba LX830; NB510; NB520; Qosmio F750, X770, X870; Satellite C660, C670, C850, C850D, C855, C855D, C870, C870D, C875, C875D, L730, L735, L750, L750D, L755, L755D, L775, L775D, L830, L850, L850D, L855, L855D, L870, L875, L875D, L955, L955D, P750, P770, P845T, P850, P855, P870, P875, R830, R930, S70, U840, U840W, U920t, U940, Z830, Z930
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- Ramp Load
- 7.9 cm
- 11.9 cm
- 1.7 cm
- 180 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Compatible Bay
- 2.5"
- Power Source
- USB bus
- OS Required
- Microsoft Windows 7
- Cables Included
- 1 x USB 3.0 cable - external
- Plug and Play
- Enclosure Colour
- Matte black
- Designed For
- Dynabook Toshiba Portégé R930-14X, R930-18L, R930-1CW, R930-1CX, R930-1CZ, R930-1D0, R930-1D7, R930-1FU, R930-1FV, Z930-13L, Z930-13M, Z930-147, Z930-14D, Z930-153 , Dynabook Toshiba Satellite Pro C850-19G, C850-1CV, C850-1D4, C850-1DC, C850-1DE, C850-1FJ, C850-1FR, C850-1GR, C850-1H8, C850-1HD, C850-1HE, C850-1K1, C850-1K2, C850-1K3, C850-1K4, C850-1LV, C850-1M7, L830-13E, L830-13R, L830-14F, L830-15W, L850-1KM, L850-1L4, L850-1MH, L850-1MJ, L850-1P7, L850-1P8, L850-1UJ, L850-1UK, L870-16Z, L870-171, L870-172, L870-179, L870-17X, L870-18G, L870-18L, L870-18R , Dynabook Toshiba Tecra R940-1GQ, R940-1JF, R940-1JG, R940-1JH, R940-1L0, R940-1L1, R950-176, R950-1EJ, R950-1EK, R950-1EL, R950-1EM, R950-1EN, R950-1JH, R950-1JJ , Toshiba LX830-11G , Toshiba Qosmio X870-13U, X870-13Z, X870-140, X870-141, X870-142, X870-149, X870-15K , Toshiba Satellite C850-1DV, C850-1DW, C850-1GL, C850-1LH, C850-1LW, C850-1M8, C850-1MC, C850D-11F, C850D-121, C850D-12L, C850D-12V, C855-1TH, C855-1TJ, C855-1U8, C855-1VU, C855-1W9, C855-1XH, C855-253, C855-25L, C855-28U, C855-29L, C855-29M, C855-29N, C855-2EE, C855-2EF, C855-2ET, C855-2EU, C855-2EZ, C855-2F0, C855-2F1, C855-2F2, C855-2F3, C855-2F7, C855-2F8, C855-2F9, C855-2FC, C855D-12P, C855D-13J, C855D-149, C855D-14C, C855D-15W, C855D-15Z, C870-17L, C870-17T, C870-17U, C870-1F3, C870-1GF, C870-1H2, C870-1HE, C870D-11X, C875-114, C875-150, C875D-10E, L830-13J, L830-14G, L830-15G, L830-15H, L830-15J, L830-160, L830-164, L850-1K8, L850-1V0, L850D-12P, L855-14K, L855-14W, L855-15L, L855-15U, L855-179, L855-17Q, L855-17R, L855D-10G, L855D-10H, L870-18Q, L870-18V, L875-12V, L955-108, L955-10F, L955-10J, L955D-104, L955D-107, L955D-10F, P845t-103, P845t-104, P845T-108, P845t-10G, P845t-10J, P850-31W, P850-31X, P850-31Z, P850-320, P850-32D, P850-32M, P850-32Z, P855-33X, P855-34P, P870-31G, P870-320, R930-1CV, S70-B-10F, U920t-10F, U920t-117, U920t-11C, U940-101, U940-104, U940-11N, Z930-13C
