Toshiba 1TB SATA 3Gb/s 5400RPM 8MB 2.5" 9.5mm Hard Drive
Quicklinx: 8WTHWS00 Mfr#: MQ01ABD100
£34.24 ex VAT
£41.08 inc VAT
The advanced MQ01ABDxxx targets markets such as portable multimedia and gaming notebooks, mobile workstations and other capacity-hungry applications like external HDDs. In addition, the drives also feature very good power efficiency value of 0.00055 for the 1 TB model. Due to the "Silent-Seek" technology featured in these drives, the HDDs are extremely quiet - ultra-silent single-platter drives are making them almost indistinguishable to the human hear.
With its compact size and best-in class specifications, the SATA MQ01ABDxxx series is the perfect choice for use in devices where a combination of sleek form factor and high capacity capabilities are essential.
Toshiba MQ01ABD100 - hard drive - 1 TB - SATA 3Gb/s
Hard drive - internal
1 TB
2.5" x 1/8H
SATA 3Gb/s
Data Transfer Rate
300 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
SilentSeek technology, shock sensor, Silent HDD, Advanced Format technology, S.M.A.R.T.
70 mm x 100 mm x 9.5 mm
112 g
Microsoft Certification
Compatible with Windows 7
1-year warranty
1 TB
2.5" x 1/8H
SATA 3Gb/s
Buffer Size
8 MB
Bytes per Sector
4096
70 mm
100 mm
9.5 mm
112 g
Performance
Drive Transfer Rate
300 MBps (external)
Seek Time
12 ms (average) / 22 ms (max)
Track-to-Track Seek Time
2 ms
Average Latency
5.55 ms
Spindle Speed
5400 rpm
Reliability
MTBF
600,000 hours
Non-Recoverable Errors
1 per 10^14
Seek Errors
1 per 10^6
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
Power Consumption
4.5 Watt (active)
RoHS, halogen-free
Limited warranty - 1 year
5 °C
55 °C
8 - 90%
Shock Tolerance
400 g @ 2ms half-sine pulse (operating) / 900 g @ 1ms half-sine pulse (non-operating)
Vibration Tolerance
1 g @ 5-500 Hz (operating) / 5 g @ 15-500 Hz (non-operating)
Sound Emission
23 dB
