Toshiba 1TB Canvio Premium USB 3.0 2.5" Portable Drive Silver
Quicklinx: DC8ZWS00 Mfr#: HDTW210ES3AA
  • High-class storage for all your files
    Up to 3 TB housed in a stylish aluminum design with diamond-cut edges, make this drive the ultimate companion for any device, no matter if on your desk or on the move.
  • Extra connectivity
    Two supported USB types for the connectivity of the future. With the small, included Type-A to Type-C USB adapter, the Canvio Premium offers everything you need for data transfers to and from different devices. So no matter if your notebook or desktop PC comes with a USB Type-A or a USB Type-C connection, the Canvio Premium has got you covered.
  • Protect your data
    Stop unauthorized users from accessing your private information with the included Toshiba Storage Security Software, allowing you to secure your hard drive with a unique password.
  • Automatic backup solution
    The included Toshiba Storage Backup Software comes with an intuitive and user-friendly interface, making the backup of your data a breeze. Simply choose your individual files or folders, intervals and time settings for your backups, and let the software take care of the rest.
  • High transfer speeds
    Powered by USB 3.0 technology, these portable hard drives are much faster than - but still compatible with - USB 2.0 devices, allowing for speedy transfer when organizing your files.
Toshiba Canvio Premium - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Password authentication, Bus Powered by USB, NTFS formatted
Power Source
USB bus
Enclosure Colour
Silver metallic, diamond cut design
78 mm x 109 mm x 13.5 mm
160 g
3-year warranty
1 TB
USB 3.0
78 mm
109 mm
13.5 mm
160 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Power Source
USB bus
Software Included
Toshiba Backup Software, Toshiba Password Protection
Microsoft Windows 7 / 8.1 / 10
Carrying pouch
1 x USB 3.0 cable - USB Type A to micro-B - external , 1 x USB adapter - USB-C to Type A - external
Enclosure Colour
Shipping Width
128 mm
Shipping Depth
140 mm
Shipping Height
40 mm
Shipping Weight
273 g
Limited warranty - 3 years
