Toshiba 160GB 1.8"" Ext Black Steel HDD
Quicklinx: 6MJ5WS00 Mfr#: PA4141E-1HA6
It is the minimalist and elegant design that makes the StorE steel unique. The casing is made up of a glossy, scratch and smudge resistant stainless steel design. It is small enough to fit easily into a laptop carry case. Furthermore the drives are very lightweight. Above all there is no need for an external power supply as StorE steel is powered via USB interface.
  • Use steel to protect your data
    This hard drive features a stainless steel, anti-scratch and anti-finger mark enclosure for a generation of solid and reliable hard disk drives.
  • Elegance meets technology
    This hard drive features a slick, modern and minimalist design for one of the most elegant products in its category.
Toshiba StorE Steel - hard drive - 160 GB - USB 2.0
Hard drive - external (portable)
160 GB
1.8"
USB 2.0
Enclosure Colour
9.1 cm x 6 cm x 1 cm
Dynabook Toshiba Portégé M750-112, M750-136, R600-11, R600-136, R830-10, R830-13, R830-138, R830-139; Toshiba Satellite Pro C660, L300D-14, L300D-21, L300D-23, L300D-236, L300D-248, L350-183, L350-225, L350-247, S300L-10, S300L-102, S300L-103, S300L-11, S300L-111, S500-10, S500-11; Toshiba Tecra A10, A10-16, A10-18, A10-19, A11, M10, M10-139, M10-15, M10-156, M10-169; NB200; Qosmio X300-13, X300-15; Satellite C660, L300-19, L300-22, L300-226, L300-24, L300-25, L300-26, L300D-13, L300D-20, L300D-21, L300D-22, L300D-242, L350D-11, L350D-20, L350D-206
160 GB
1.8"
USB 2.0
9.1 cm
6 cm
1 cm
Expansion & Connectivity
1 x USB 2.0 - 4 pin USB Type A
Compatible Bay
1.8"
Microsoft Windows Vista / 2000 / XP
System Requirements Details
Windows 2000/XP/Vista - 750 MHz - RAM 256 MB (USB 2.0)
1 x USB cable - external - 30 cm
Enclosure Colour
Dynabook Toshiba Portégé M750-112, M750-136, R600-11B, R600-11Q, R600-136, R830-10Q, R830-138, R830-139, R830-13C , Dynabook Toshiba Satellite Pro C660-2KL, C660-2N2, L300D-14U, L300D-21R, L300D-236, L300D-23X, L300D-248, L350-183, L350-225, L350-247, S300L-102, S300L-103, S300L-10E, S300L-10F, S300L-111, S300L-11U, S500-10E, S500-11C , Dynabook Toshiba Tecra A10-16E, A10-18M, A10-19M, A10-1C0, A10-1C1, A10-1E1, A10-1EC, A11-1J7, M10-139, M10-156, M10-15J, M10-169, M10-1CH, M10-1D7, M10-1D8, M10-1DC , Toshiba NB200-110, 113, 11L , Toshiba Qosmio X300-13E, X300-13I, X300-15Q , Toshiba Satellite C660-1PD, C660D-1EH, L300-19N, L300-226, L300-22U, L300-24W, L300-25H, L300-26G, L300D-13E, L300D-20D, L300D-20Z, L300D-21L, L300D-22F, L300D-242, L350D-11O, L350D-206, L350D-20E, L350D-20P
