Toshiba 128GB TransMemory U202 USB 2.0 Drive - white
Quicklinx: BR0ZWS00 Mfr#: THN-U202W1280E4
TransMemory™ U202
STORAGE MADE SIMPLE
The Toshiba TransMemory™ U202 USB flash drive makes it simple to store media – with a design that's small in size, but big on storage, with a choice of memory sizes. And with protection software, the TransMemory™ U202 also provides data security – enabling you to set a password for the entire device, or one specific block of data. Behind the practical and attractive design is a flash drive that you can take everywhere, for access to media anywhere.
PRACTICAL AND PORTABLE
With a small and lightweight design, the Toshiba TransMemory™ U202 is designed to go wherever you go. Simple and flexible storage is housed in a practical and attractive design, so documents, music, photos and more can go anywhere – effortlessly.
STORAGE MADE SAFER
Additional security software means that whatever you choose to store, it stays protected and private. With password support for the entire device, or specific blocks, your data is kept safe.
QUALITY YOU CAN TRUST
Toshiba is the inventor of flash memory, and has a well-earned worldwide reputation for producing high quality technology.
  • USB 2.0 standard
    The USB 2.0 standard A Type has a size of 12 mm width and a height of 4.5 mm. Suitable in all USB 2.0 ports which is standard in every PC. Data transmission is possible in both directions.
  • Hot plug and unplug
    Devices can be connected and detected during operation. Just plug and play and transfer your favorite music and images.
  • One of the lowest power consumption in the industry
    Low power consumption is achieved thanks to Toshiba's original technology, such as multi-layering of high-speed NAND flash memory and a dedicated low-power-consumption ASIC controller. As a result, power consumption of notebook PCs is minimized even when using a USB flash memory.
Toshiba TransMemory U202 - USB flash drive - 128 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
128 GB
Enclosure Colour
White
Apple MacOS X 10.0.2 or later, Microsoft Windows 2000/XP/Vista/7/8
5-year warranty
USB flash drive
Storage Capacity
128 GB
Enclosure Colour
White
Read Rate
Up to 18 MB/s
Write Rate
Up to 5 MB/s
Interface Type
USB 2.0
Limited warranty - 5 years
21.4 mm
51.4 mm
8.4 mm
8 g
50 °C
20 - 95% (non-condensing)
