Product
Brand
TomTom Start 20 M UK-IE (UK-IE)
Quicklinx: B7STWS00 Mfr#: 1EN4.013.02
A convenient foldaway mount that's integrated with your device, so it's always there when you need it. It attaches easily to your windscreen. And using the optional mounting disk, you can turn it upside down and position it on your dashboard too, where the screen automatically flips to the right way up.
Find nearby parking with the aid of your TomTom device. Since Parking Assist is available throughout your journey, you can choose to navigate directly to the nearest car park when planning your route, or find parking en route - either nears your destination or close to your current location.
TomTom Start 20 M - GPS navigator
GPS navigator
Display
Colour widescreen
Touch Screen
Recommended Use
Automotive
Voice
Navigation instructions
GPS navigator
Recommended Use
Automotive
Voice
Aerial
Built-in
Display
Colour - touch screen
Diagonal Size
Widescreen
