TMC Technology VISION TM-CC TECHMOUNT CLOSE-C
Quicklinx: 7BG8WS00 Mfr#: TM-CC
Accessory Type: Mount
24 In Stock
£37.74 ex VAT
£45.28 inc VAT
The Techmount TM-CC is a universal projector ceiling bracket designed to secure 99% of data projectors safety and sturdily to ceilings. It is designed for applications where no 'drop' is required so no pole is included.
  • Robust construction
    High standard of finish and over-engineered for stability and safety. A rugged high-quality satin-white finish blends with ceiling tiles.
  • Maneuverable
    The top and bottom parts can rotate 360 degrees, and the spider arms have a maximum span of 340mm.
  • Sloping ceilings
    A tilting mechanism is built in allowing you to use the bracket with cathedral-type ceilings.
  • Safety approved
    The TM-CC has a recommended maximum safe working load (SWL) of 10kg which is well within the limits of the product.
Vision Techmount TM-CC mounting kit - for projector - satin white
Mounting kit
Recommended Use
Projector
Max Load Weight
10 kg
Satin white
Satin white
AV Furniture
Mounting kit
Recommended Use
Projector
Max Load Weight
10 kg
Brand: TMC Technology
