This stereo gaming headset provides pure analog audio for accurate, optimal reproduction of the sound of games on your PC. Enjoy crystal-clear audio, via premium drivers: hear everything, react quickly! Unidirectional mic is designed to accurately target just your voice, for effective communication with your teammates.
Audio expertise
Enjoy crystal-clear audio, via premium drivers: hear everything, react quickly! At last, you can properly hear the bass frequencies from explosions! Audio sensations are even more real than real life, thanks to the stable frequency response curve optimized for your gaming sessions, with perfect equilibrium between bass, mids and treble. -
High-performance microphone
Unidirectional mic is designed to accurately target just your voice, for effective communication with your teammates. Microphone is detachable and adjustable, to adapt to every player's head size and shape. Adjust the gain precisely for your voice, so that you'll be perfectly understood by your teammates. -
Designed for comfort and performance
Unique design, crafted by ThrustMaster's team provides outstanding comfort: large, ultra-soft ear pads and a headband covered in thick, soft foam padding for extreme comfort during long gaming sessions and reliable, effective passive isolation. Exclusive acoustic bass amplification system is provided thanks to the earpieces' unique design. -
Advanced controls
Controls are at your fingertips, thanks to the multifunctional controller on the cable: no need to fumble with your PC's settings.
- ThrustMaster Y-250C - headset
- Product Type
- Headset - wired
- Recommended Use
- Game console, portable electronics, computer
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 10 - 25000 Hz
- Microphone
- Detachable - boom
- Controls
- Microphone on/mute, phone/music mode
- Product Type
- Headset - wired
- 364 g
- Recommended Use
Audio Output
- Full size
- Wired
- Sound Output Mode
- Stereo
- 10 - 25000 Hz
- Diaphragm
- 50 mm
- In-Cord Volume Control
Microphone
- Boom
- Sensitivity
- -50 dB
- Audio Input Details
- Uni-directional
Remote Control
- Controls
- Connector Type
- Headset
- Cable Details
- Headset cable - 2.8 m
