Thrustmaster TS-XW Racer Sparco P310 Competition Mod
Quicklinx: GV2TWS00 Mfr#: 4468009
£457.50 ex VAT
£549.00 inc VAT
FORCE FEEDBACK BASE WITH A POWERFUL BRUSHLESS SERVOMOTOR
The TS-XW Racer motor provides powerful 40-watt brushless Force Feedback and incredible velocity (dynamic torque): from long stall curves (STALL mode) to super-responsive S curves (DYNAMIC mode). The wheel’s Motor Cooling Embedded cooling system maintains the new motor’s dynamics, avoiding overheating while staying very quiet. The TS-XW Racer Sparco P310 Competition Mod features an angle of rotation that can be adjusted from 270° all the way to 1080°. The wheel component itself weighs less than 2.6 lb / 1.2 kg, for optimal inertia and extremely realistic Force Feedback sensations.
THRUSTMASTER ECOSYSTEM
Ecosystem-ready, the wheel can easily be detached from the Thrustmaster TS-XW servo base thanks to the handy Thrustmaster Quick Release system. The TS-XW Racer racing wheel is compatible with all products in Thrustmaster’s racing ecosystem. The wheel is also compatible with Thrustmaster’s realistic, high-end TH8A add-on shifter (sold separately).
FIELD ORIENTED CONTROL ALGORITHM
The H.E.A.R.T (HallEffect AccuRate Technology™) system provides 16-bit resolution (65,536 values), while the new Field Oriented Control (F.O.C.) algorithm dynamically optimizes the response to intense torque demands.
TURBO POWER
The external Turbo Power power supply delivers constant power and massive peak power, to instantly respond to ultra-fast requests from the game. Toroidal-shaped for optimized power efficiency of 86% (with just 14% heat generation), with a finless design. Peak power: 400 watts!
PEDAL SET INCLUDED
Featuring a 100% metal internal structure, plus a Conical Rubber Brake Mod (with ultra-progressive resistance at the end of the brake pedal’s travel), the T3PA pedal set is also fully adjustable, allowing it to be perfectly adapted to gamers’ needs. The three pedals can be adjusted in terms of their height, inclination and spacing, for optimal customization.
Compatible with Series X/S & PC
Dimensions
  • Length (cm) 52.5
  • Width (cm) 38
  • Height (cm) 31
  • 13.3KG
Box Content
  • Racing wheel
  • pedal set
  • Turbo Power power supply
  • attachment system compatible with all desks tables, etc.
  • user manual and consumer warranty information.
  • The first milestone of the collaboration between Thrustmaster and Sparco
    Thrustmaster presents the TS-XW Racer Sparco P310 Competition Mod racing wheel: the first milestone of the collaboration between Thrustmaster and Sparco. It is the result of a combination of the advanced technologies such as a powerful 40-watt brushless servomotor, Motor Cooling Embedded system and Turbo Power power supply. It is officially licensed for Xbox One and Windows.
  • Realistic "competition" wheel design
    12.4"/31.5 cm in diameter: 1:1 scale replica of the Sparco P310 Competition wheel, with an ergonomic design perfectly adapted for all racing games (GT, F1, NASCAR, Indy, road racing, etc. ). Thrustmaster TS-XW servo base, detachable Sparco wheel with metal faceplate and genuine suede leather. ECOSYSTEM-READY. 2 large, wheel-mounted sequential paddle shifters (5"/13 cm tall - 100% metal - tact switch with life cycle exceeding 500,000 activations). 12 action buttons + 1 directional pad with push button function.
  • Powerful brushless servomotor Force Feedback base
    TS-XW Racer motor provides powerful 40-watt brushless Force Feedback and incredible velocity (dynamic torque): from long stall curves (STALL mode) to super-responsive S curves (DYNAMIC mode). Motor Cooling Embedded system (patent pending): maintains dynamics with the motor, by ensuring that there is no overheating and while remaining silent. Built-in official buttons for Xbox One: Xbox Guide, View and Menu. Switch between the game, system menus, social features, etc. Rotation angle adjustable from 270° to 1080°! Field Oriented Control: H.E.A.R.T (HallEffect AccuRate Technology) provides 16-bit resolution (65,536 values), while the new F.O.C. algorithm dynamically optimizes the response to intense torque demands. External Turbo Power power supply delivers constant power and massive peak power, to instantly respond to ultra-fast requests from the game. Toroidal-shaped for optimized power efficiency of 86% (with just 14% heat generation), with a finless design. Peak power: 400 watts! Dual belt-pulley system with metal ball-bearing axle. Internal memory and upgradeable firmware. Robust and versatile attachment system, compatible with all mounts (desks, tables, etc. ).
ThrustMaster TS-XW Racer Sparco P310 Competition Mod - wheel and pedals set - wired
Wheel and pedals set
Wired
PC, Microsoft Xbox One
Wired
USB
Game Controller (1st) Details
Wheel
Buttons Qty
13
Controls
Direction pad, 12 action buttons, 2 paddle shifters
Built-in fan, built-in flash memory, force feedback, H.E.A.R.T HallEffect AccuRate Technology, quick release system, sequential paddle shifters, dual-belt mechanism, detachable wheel, LED indicator, 270 to 1080° wheel rotation, firmware upgradeable
Game Controller (2nd) Details
Pedals
Height-adjustable, adjustable pedal angle, brake pedal progressive resistance, adjustable spacing
Microsoft Windows Vista / 7 / 8 / 10
Type: Wheel and pedals set
Type: Wheel
Wired / Wireless: Wired
Compatibility: Microsoft Xbox One
Compatibility: PC
Compatibility: Microsoft Xbox One X
Compatibility: Microsoft Xbox One S
Compatibility: Microsoft Xbox Series S
Compatibility: Microsoft Xbox Series X
Brand: Thrustmaster
