Thrustmaster TCA Yoke Pack Boeing Ed
Quicklinx: H0N8WS00 Mfr#: 4460210
More than 50 In Stock
£332.50 ex VAT
£399.00 inc VAT
TCA Yoke Pack Boeing Edition is an aviation system officially licensed by both Boeing and Xbox, for Xbox One and Xbox Series X|S. It is also compatible with PC.
FEELS LIKE A DREAM
TCA Yoke Pack Boeing Edition is an aviation system officially licensed by both Boeing and Xbox, for Xbox One and Xbox Series X|S. It is also compatible with PC. TCA Boeing Edition, Thrustmaster’s new flagship civil aviation range, is a line of products allowing for cutting-edge new features with a highly-specific goal in mind: replicating the different controls, flight kinematics and sensations experienced by real Boeing pilots at the controls of a 787 airliner.
SUSPENDED PENDULAR MECHANISM
Thrustmaster’s suspended PENDULAR mechanism replicates the sensations of using a floor-mounted pendular yoke — like those found in real Boeing airliners — in an exciting new way. TCA Yoke Boeing Edition features a long 8.3-inch / 21-cm range of travel.
2 ADDITIONAL AXES
TCA Yoke Boeing Edition features 2 additional axes on its base, allowing for a variety of standalone maneuvers — including the ability to directly take off without having to use a throttle quadrant.
100% METAL FRAME
The yoke’s internal structure is 100% metal, for excellent sturdiness and balanced weight distribution of the controls, allowing for outstanding stability.
ADJUSTABLE SPRINGS
TCA Yoke Boeing Edition lets gamers adjust the number of internal springs (2 to 4 springs can be used simultaneously). This allows users to set the amount of resistance according to their own personal preferences, for truly exceptional control.
SWAPPABLE LEVERS
All throttle quadrant levers (4 included) can be swapped, allowing for an ambidextrous flight experience thanks to the ability to place the speed brake and flaps levers in the user’s choice of position.
BOEING REAL-LIFE LINEAR RESISTANCE FEEL
Inspired by the real-world sensations experienced with the real Boeing Dreamliner throttle quadrant, TCA Quadrant Boeing Edition replicates the actual resistance force felt by pilots when moving the thrust levers up or down.
BOEING AUTOPILOT
TCA Quadrant Boeing Edition includes the iconic Boeing autopilot feature for realistic control of the aircraft’s altitude, airspeed and heading. The design and operation of this rotary knob were also inspired by the real Boeing Dreamliner throttle quadrant.
Box Contents
- 1 x TCA Yoke Boeing Edition
- 1 x TCA Quadrant Boeing Edition
- 1 x TM Flying Desk Mount
- Yoke: 1 x USB cable (type C to type A), 1 x support stand for tablet or smartphone, 1 x Allen key
- Throttle quadrant: 4 x interchangeable levers, 1 x crossbar, 2 x attachment pieces
- 1 x connection poster, 1 x spring installation flyer
- 3 x warranty information flyer
  • Feels like a dream
    TCA Yoke Pack Boeing Edition is an aviation system officially licensed by both Boeing. It is compatible with PC and console.
  • Suspended PENDULAR mechanism
    Thrustmaster's suspended PENDULAR mechanism replicates the sensations of using a floor-mounted pendular yoke - like those found in real Boeing airliners - in an exciting way.
  • 2 additional axes
    TCA Yoke Boeing Edition features 2 additional axes on its base, allowing for a variety of standalone maneuvers - including the ability to directly take off without having to use a throttle quadrant.
  • 100% metal frame
    The yoke's internal structure is 100% metal, for excellent sturdiness and balanced weight distribution of the controls, allowing for outstanding stability.
  • Adjustable springs
  • Swappable levers
    All throttle quadrant levers (4 included) can be swapped, allowing for an ambidextrous flight experience thanks to the ability to place the speed brake and flaps levers in the user's choice of position.
  • Boeing real-life linear resistance feel
  • Boeing autopilot
    TCA Quadrant Boeing Edition includes the iconic Boeing autopilot feature for realistic control of the aircraft's altitude, airspeed and heading. The design and operation of this rotary knob were also inspired by the real Boeing Dreamliner throttle quadrant.
  • Magnetic technology
    TCA Yoke Pack Boeing Edition features proprietary H.E.A.R.T magnetic technology, for surgical precision (16-bit resolution) on each of the flight controllers' main axes (yoke and throttle quadrant).
Thrustmaster Civil Aviation (TCA) Yoke Pack Boeing Edition - yoke and throttle - wired
Yoke and throttle
Wired
PENDULAR technology, 2 additional axes
PC, Microsoft Xbox One, Microsoft Xbox Series S, Microsoft Xbox Series X
Yoke and throttle
Wired
Game Controller (2nd) Details
Throttle
3 axis, H.E.A.R.T HallEffect AccuRate Technology, magnetic technology, autopilot feature, swappable levers
30 cm
39 cm
38 cm
6.7 kg
Type: Yoke
Type: Flight Stick
Wired / Wireless: Wired
Compatibility: PC
Compatibility: Microsoft Xbox Series X
Compatibility: Microsoft Xbox Series S
Compatibility: Microsoft Xbox One
Brand: Thrustmaster
