Thrustmaster T150 Force Feedback Wheel PS4/PS3/PC
Quicklinx: C1VFWS00 Mfr#: 4168053
1080° Force Feedback base featuring Immersion TouchSense® technology
Drive system with adjustable Force Feedback lets you feel every detail while you’re racing (the road or track’s relief, loss of tire grip, braking, bumps and impacts, etc.).
Rotation angle adjustable from 270° to 1080°!
Very precise wheel: optical reading with 12-bit resolution (i.e. 4,096 values on the wheel’s steering axis)
Mixed belt-pulley and gears system Smoother, more fluid and less noisy than helical gears with metal ball-bearing axle (for enhanced sturdiness)
Internal memory and upgradeable firmware
Robust and versatile attachment system, compatible with all mounts (desks, tables, etc.)
PlayStation®4-certified embedded software and PS4™/PS3™ sliding switch
  • Official embedded software: the racing wheel is automatically recognized by the PS4™ console
  • Compatible in the console’s menus
  • PS4™/PS3™ sliding switch for optimal compatibility on both systems
Also compatible with PC
PC compatibility (Windows® 10/8/7/Vista) ensured thanks to the Thrustmaster drivers available for download from the http://ts.thrustmaster.com/ website. The drivers allow you to make sure that you always have the latest firmware version available for the racing wheel’s base.
Realistic wheel
Built-in official buttons for PlayStation®4 (PS/SHARE/OPTIONS) Access social functions, switch between the game and the system,navigate through the console’s menus, etc.
11"/28 cm in diameter, with an ergonomic design perfectly adapted for all driving games (GT, F1, NASCAR, Rally, etc.) Rubber-coated wheel grips
2 large, wheel-mounted sequential paddle shifters 5"/13 cm tall – 100% metal – Tact switch with life cycle exceeding 500,000 activations
Comprehensive driving gear 13 action buttons (including 2 on the base) + 1 D-Pad
  • 1080-degree force feedback
    Drive system with adjustable force feedback lets you feel every detail while you're racing (the road or track's relief, loss of tire grip, braking, bumps and impacts, etc.). Rotation angle is adjustable from 270 degrees to 1080 degrees! T150 features a very precise wheel, mixed belt-pulley and gears system. Smoother, more fluid and less noisy than helical gears with metal ball-bearing axle (for enhanced sturdiness).
  • Large, optimized pedal set
    Pedals with wide foot rest. Each pedal's angle of inclination can be adjusted. Features a brake pedal with progressive resistance.
  • Realistic wheel
    Access social functions, switch between the game and the system, navigate through the console's menus with an ergonomic design perfectly adapted for all driving games. Features rubber-coated wheel grips and 2 large, wheel-mounted sequential paddle shifters.
  • Comprehensive driving gear
    Comes with 13 action buttons (including 2 on the base) + 1 D-Pad.
ThrustMaster T150 - wheel and pedals set - wired
Wheel and pedals set
Wired
Sony PlayStation 4
Wired
Sony PlayStation 4
