Thrustmaster T-248 Xbox Series X/S
Quicklinx: GV2SWS00 Mfr#: 4468010
Type: Wheel and pedals set, Wheel
Wired / Wireless: Wired
Compatibility: Sony PlayStation 5, PC, Sony PlayStation 4
£224.99 ex VAT
£269.98 inc VAT
Designed for all gamers looking for performance and immersion and wanting to free themselves from their keyboard, mouse or gamepad, or improve their skills after starting out with a beginner’s wheel, T248 is a racing wheel officially licensed for Xbox Series X|S, Xbox One, and compatible with PC.
THRUSTMASTER RACE DASHBOARD DISPLAY
T248 features a selection of more than 20 different displays on its built-in screen: manual adjustment of a range of settings (selection of Force Feedback type, the wheel’s rotation angle, etc.), or the user’s choice of telemetry information (gear ratio, RPM, gamer’s best lap time, etc.). The list of compatible games on PC and Xbox console are available on the Thrustmaster technical support website, and regularly updated.
DYNAMIC FORCE FEEDBACK
T248 features 3 types of Force Feedback (presets included), compatible with all games and modifiable on the fly directly on the wheel: FFB 1: Force Feedback 100% proportional to the force requested by the game. FFB 2: enhanced Force Feedback, for better skid control. FFB 3: boosted Force Feedback, allowing users to clearly feel all racing effects from the track (curbs, skidding off-track, etc.).
NEXT-GEN HYBRID DRIVE SYSTEM
Providing gamers with extra power (up to 70% more than the previous Thrustmaster hybrid racing wheel, TMX), T248 dominates racetracks thanks to its intensity. The outstanding drivability made possible by this hybrid system avoids counterintuitive sensations and friction problems commonly found in racing wheels without a belt drive component.
25 ACTION BUTTONS
Including 2 dual-position encoders (up and down) located on the ends of the wheel’s central spokes, T248 features nearly twice as many action buttons as previous Thrustmaster racing wheels (TMX series). This extensive range of physical and virtual buttons allows users to always have plenty of choices when it comes to assigning racing controls, in any type of game.
MAGNETIC PADDLE SHIFTERS
Thanks to H.E.A.R.T magnetic technology, T248’s paddle shifters allow for super-fast gear shifting, with clear and precise activation feel (30 ms response time) to avoid driving errors. This proprietary technology, based on a contactless system of magnets without any friction, also allows for an unprecedented product lifespan over the long term — even with the most intense gaming sessions.
MAGNETIC PEDAL SET
Providing truly exceptional, thousandth-of-a-second precision, the T3PM magnetic pedal set also allows for 4 pressure modes on the brake pedal. With completely smooth motion and avoiding the loss of precision over time experienced by standard potentiometer-based pedal sets, T3PM represents a huge, striking leap forward both in terms of versatility and in-game responsiveness.
Dimensions
  • WHEEL AND BASE
  • Width: 11 inches / 280 mm
  • Depth: 11.8 inches / 300 mm
  • Height: 11 inches / 280 mm
PEDAL SET
  • Width: 11.8 inches / 300 mm
  • Depth: 14.6 inches / 370 mm
  • Height: 8.3 inches / 210 mm
  • Wheel and base - 2.7KG
  • Pedal Set - 3KG
Box Content
  • T248 wheel and base
  • T3PM pedal set
  • 48 W power supply + power cable
  • Attachment system + screws
  • USB cable
  • Allen key
  • Quick start guide
  • Warranty information flyer Depth: 14.6 inches / 370 mm Height: 8.3 inches / 210 mm
  • Thrustmaster race dashboard display
    T248 features a selection of more than 20 different displays on its built-in screen: manual adjustment of a range of settings (selection of Force Feedback type, the wheel's rotation angle, etc.), or the user's choice of telemetry information (gear ratio, RPM, gamer's best lap time, etc.).
  • Next-gen Hybrid Drive system
    Providing gamers with extra power, T248 dominates racetracks thanks to its intensity. The outstanding drivability made possible by this hybrid system avoids counterintuitive sensations and friction problems commonly found in racing wheels without a belt drive component.
  • 25 action buttons
    The extensive range of physical and virtual buttons allows users to always have plenty of choices when it comes to assigning racing controls, in any type of game.
  • Magnetic paddle shifters
    Thanks to H.E.A.R.T magnetic technology, T248's paddle shifters allow for super-fast gear shifting, with clear and precise activation feel (30 ms response time) to avoid driving errors. This proprietary technology, based on a contactless system of magnets without any friction, also allows for an unprecedented product lifespan over the long term.
  • Magnetic pedal set
ThrustMaster T248 - wheel and pedals set - wired
Wired
PC, Sony PlayStation 4, Sony PlayStation 5
Wired
Game Controller (1st) Details
Wheel
Buttons Qty
25
Controls
Triangle key, Circle key, Cross key, Square key, directional buttons, Display button, Share button, L1 Button, L3 Button, R1 Button, R3 Button, R2 Button, L2 Button, pause button, mode button, Create button
LCD screen, force feedback, H.E.A.R.T HallEffect AccuRate Technology, leather-wrapped wheel, on-the-fly programmable buttons
Game Controller (2nd) Details
Pedals
H.E.A.R.T HallEffect AccuRate Technology, magnetic technology
USB cable, screw, attachment system, allen key
28 cm
30 cm
28 cm
2.7 kg
Type: Wheel
Compatibility: PC
Compatibility: Sony PlayStation 4
Brand: Thrustmaster
