UNDER THE HOOD
In order to guarantee exclusive high-precision performance, pitch and roll on the T.16000M FCS flight stick employ H.E.A.R.T HallEffect AccuRate Technologyâ„¢ (U.S. patent US08471815) for . 16000 x 16000 values - the same pinpoint accuracy delivered by the extremely high-end HOTAS Warthog joystick, allowing gamers to engage their enemies with surgical precision. The helical spring (0.1" / 2.8 mm in diameter) inside the stick provides firm, linear and smooth tension.
The T.16000M FCS features 4 independent axes, including twist rudder (controlled by rotating the stick), 16 action buttons with "braille"-style physical button identification, one 8-way Point of View (PoV) hat switch and an ergonomic trigger. Its striking orange accents and backlighting bring gamers' immersion to a whole new level.
Alternative to using a mouse and keyboard. It is composed of the flight stick, the TWCS throttle and the TFRP. The T.16000M FCS flight pack is compatible with PC via USB.
T.16000M FCS
The T.16000M FCS features independent axes, including twist rudder (controlled by rotating the stick) and progressive throttle, action buttons with "braille"-style physical button identification, one 8-way point-of-view (PoV) hat switch and an ergonomic trigger. Its striking accents and backlighting bring gamers' immersion to another level. -
T.Flight rudder pedals
The TFRP features slide rails, crafted of industrial-grade anodized aluminum. The rails' unique design ensures totally smooth sliding motion, working in conjunction with a self-centering rudder axis: the combination of these two elements provides the perfect balance between smoothness and resistance for re-centering. -
TWCS throttle and S.M.A.R.T (sliding motion advanced rail track)
S.M.A.R.T (sliding motion advanced rail tracks) technology: a unique system of slide rails for perfectly smooth throttle sliding motion and precision. The TWCS throttle's lower positioning provides unrivaled comfort along its entire range of travel, for smooth and accurate control. The tightening screw allows users to adjust the throttle's friction level to suit their own personal taste. -
Ergonomic design for optimum comfort and precision
Thanks to its design and ergonomics, the T.16000M FSC flight pack provides players with multiple recognizable features, allowing them to become more effective and accurate when in flight. This enhanced access to flight controls proves even more essential when players are fully immersed in the exceptional flight experience delivered by VR-compatible games.
- ThrustMaster T.16000M FCS Flight Pack - joystick, throttle and pedals - wired
- Product Type
- Joystick, throttle and pedals
- Connectivity Technology
- Wired
- H.E.A.R.T HallEffect AccuRate Technology
- 2-year warranty
- Designed For
- PC
- Product Type
- Wired
- Interface
- USB
Game Controller (1st) Details
- Joystick
- Buttons Qty
- 16
- Controls
- 8-way hat switch, trigger, 16 action buttons
- 4 axis
Game Controller (2nd) Details
- Throttle
- Controls
- 2 analogue levers, 8-way hat switch, 14 action buttons, toggle rudder, rotary aerial
- 5 axis, S.M.A.R.T technology
Game Controller (3rd) Details
- Pedals
- Controls
- 2 pedals
- S.M.A.R.T technology
- Software Included
- T.A.R.G.E.T (Thrustmaster Advanced pRogramming Graphical EdiTor)
- 42.5 cm
- 44.5 cm
- 61 cm
- 1.1 kg
- Limited warranty - 2 years
- Designed For
- PC
