Thrustmaster Next Level Racing FGT Lite Cockpit
Quicklinx: GDJ1WS00 Mfr#: NLR-S015
£217.63 ex VAT
£261.15 inc VAT
ABOUT
Introducing a portable racing cockpit, Next Level Racing® F-GT Lite. The revolutionary design allows you to be in true racing positions for both Formula and GT racing in the comfort of your home. As a result of its minimalist design, F-GT Lite is the ideal cockpit for any user with limited space. With new innovative Next Level Racing® Hubs, the user can switch racing positions quickly and find a comfortable GT and Formula racing position.
REVOLUTIONARY ADJUSTMENT HUBS
The Next Level Racing® Hubs have been developed and engineered for over two years to offer ultimate durability and rigidity with each hub being able to withstand 150kg of force. The Next Level Racing® Hubs allows for different angle adjustability to ensure that the user is getting the most comfortable racing position. Thanks to the quick release mechanism, the Hubs have a full range of adjustability to change from Formula to GT. The Next Level Racing® Hubs also make it a perfect solution for storage, meaning the product can be folded and stored after racing.
FORMULA AND GT RACING POSITIONS
The new Next Level Racing® Hubs allow for quick and easy adjustments enabling users to switch between GT and Formula racing positions with ease. The F-GT Lite allows two true racing positions that users can enjoy with quick release adjustment features.
PRE-DRILLED AND HARD MOUNTED
The F-GT Lite is pre-drilled to hard mount electronics like wheels, gear shifters and pedals to provide a rigid racing experience as well as full adjustability to ensure different size users can find the most comfortable racing position. The F-GT Lite is compatible with all major wheels and pedals and pre-drilled for Logitech®, Thrustmaster®, Fanatec® and supports wheels that have clamping mounting options. The included Gear Shifter support can be installed on either the left or right hand side.
PORTABILITY AND STORAGE TAKEN TO THE NEXT LEVEL
The F-GT Lite’s unique award-winning design folds to pack away even with electronics installed, allowing the user to easily store their cockpit when not in use, making it the perfect cockpit for sim racers that have limited space. This also allows the F-GT Lite to be portable and for the user to take their racing setup from room-to-room when needed.
  • Revolutionary adjustment hubs
    The Next Level Racing Hubs allows for different angle adjustability to ensure that the user is getting the most comfortable racing position. Thanks to the quick release mechanism, the Hubs have a full range of adjustability to change from Formula to GT. The Next Level Racing Hubs also make it a perfect solution for storage, meaning the product can be folded and stored after racing.
  • Formula and GT racing positions
    The Next Level Racing Hubs allow for quick and easy adjustments enabling users to switch between GT and Formula racing positions with ease. The F-GT Lite allows two true racing positions that users can enjoy with quick release adjustment features.
  • Pre-drilled and hard mounted
  • Portability and storage taken to the next level
    The F-GT Lite's unique design folds to pack away even with electronics installed, allowing the user to easily store their cockpit when not in use, making it the perfect cockpit for racers that have limited space. This also allows the F-GT Lite to be portable and for the user to take their racing setup from room-to-room when needed.
Next Level Racing F-GT Lite - racing simulator cockpit
Racing simulator cockpit - tilt
Gaming
Headrest
Casters
Assembly Required
120 cm - 200 cm
19 kg
Package Content
Frame, screws, gear shifter adapter
Gaming
Headrest
Casters
Max Load Weight
130 kg
Assembly Required
Foldable, breathable, pre-drilled
Base
Design
Frame
120 cm - 200 cm
19 kg
Dimensions & Weight Details
Folded - width: 75 cm depth: 40 cm height: 87 cm
Shipping Width
77 cm
Shipping Depth
67.5 cm
Shipping Height
22 cm
Shipping Weight
20 kg
