Thrustmaster Hotas Warthog Joystick and Throttle for PC
Quicklinx: 75W2WS00 Mfr#: 2960720
Type: Throttle, Joystick
Wired / Wireless: Wired
Compatibility: PC
21 left in stock
£357.50 ex VAT
£429.00 inc VAT
The Hotas Warthog™ is an U.S. Air Force A-10C attack aircraft HOTAS™ (Hands On Throttle And Stick) replica joystick high end system including:
Dual Replica THROTTLES
Software suite: T.A.R.G.E.T (Thrustmaster Advanced pRogramming Graphical EdiTor)
Replica JOYSTICK
Replica A-10 Flight Stick
Innovative new H.E.A.R.T HallEffect AccuRate Technology:
- 3D magnetic sensors (Hall Effect) on the stick: enjoy surgical precision that stays razor-sharp over time
- 16-bit resolution (65536 x 65536 values)
- 5 coil spring system: firm, linear and fluid tension, with no dead zones
USB connection with upgradeable firmware
Super-stable, weighted base (over 3kg)
New detachable handle, crafted entirely of metal:
- also compatible with HOTAS COUGAR™ handle (and vice-versa)
- new replica shape
- detachable metal plate for desk- or cockpit-style use
- new, realistic pressure on buttons and trigger
- 19 action buttons in total + one 8-way "point of view" hat:
. 1 x 8-way "point of view" hat
. 2 x 8-way hats
. 1 x 4-way hat with push button
. 1 x metal dual trigger
. 2 x push buttons
. 2 x pinkie push buttons
- 3D magnetic sensors (Hall Effect) on the 2 throttles: enjoy surgical precision that stays razor-sharp over time
- 14-bit resolution (16384 values) on each throttle
Dual throttles, featuring:
- metal hand rest
- locking system
- adjustable friction system: firm, linear and fluid tension, with no dead zones
- realistic IDLE detent with "Pull & Push" system
- realistic and disengageable AFTERBURNER detent with "Pull & Push" system
- realistic pressure on buttons and switches
- 17 action buttons in total + 1 mouse hat with push button + one 8-way "point of view" hat:
. 1 x mouse hat with push button and 3D magnetic sensor (Hall Effect)
. 1 x 8-way hat
. 1 x push button
. 1 x 3-position switch (2 momentary + 1 permanent)
. 2 x 3-position switches (3 permanent)v . 1 x 3-position switch (1 momentary + 2 permanent)
Replica Control Panel
Weighted base (over 3kg) incorporated underneath the throttles
Backlit functions
5 programmable LEDs
Realistic pressure on buttons and switches
15 action buttons in total + 1 TRIM wheel:
. 1 x TRIM wheel
. 2 x push buttons
. 5 x 2-position switches (2 permanent)
. 2 x 3-position switches (1 momentary + 2 permanent)
SOFTWARE SUITE: T.A.R.G.E.T (Thrustmaster Advanced programming graphical editor)
To test, configure and program Thrustmaster® controllers: HOTAS WARTHOG™, MFD Cougar, HOTAS Cougar™ and T.16000M
Uses the "Drag and Drop" principle
Multiple programming levels: Basic, Advanced and Script
  • Thrustmaster HOTAS Warthog joystick
    The HOTAS Warthog USB dual-throttle joystick is the result of an intense collaboration between Thrustmaster's development teams and members of the "simmer" community. Exchanges and studies were carried out constantly throughout the product's development phase, in order to create a joystick which meets specific and precise requirements of the experts. Using metal for the joystick, throttle handles, and bases, the HOTAS Warthog joystick is physically imposing. When you consider the 55 fully programmable action buttons and 2 four-direction hat switches, each with a built-in push button, it becomes clear that the HOTAS Warthog is truly exceptional.
  • Precise and feature-filled
    The joystick features 19 action buttons, along with a "Point of View" hat. It provides extreme precision, thanks to the H.E.A.R.T HallEffect AccuRate Technology magnetic sensor system it employs: 16-bit precision (65536 x 65536 values), with no gimbals (cardan joints). What's more, pressing on the joystick's buttons and triggers requires pressure identical to that required in an actual airplane - a true first in the world of joysticks. Particular attention has been paid to freedom of use for simmers, with the joystick's handle being detachable, and its base being detachable as well (allowing you to install the joystick in the cockpit).
  • Pull and push throttle system with disengageable afterburner
    The throttle component has also been very carefully designed, with a dual throttle system allowing for independent control of 2 motors: a locking system lets the user either attach the 2 throttles together or keep them independent of one another. The magnetic sensor technology used for the throttles (14-bit resolution, with 16384 values on each throttle) provides unrivaled precision. Switching to the Idle and Afterburner detents is carried out via a Pull and Push system, for even greater realism. The Afterburner detent is disengageable, allowing users to perfectly adapt the throttle control to the type of airplane they are piloting.
  • Control panel with 5 programmable LEDs
    The product's final mechanical component, the control panel, provides an extensive number and variety of controls. It includes a friction wheel, allowing users to manually adjust the resistance of the throttles according to their own taste. It also features backlighting for functions, which users will certainly appreciate for night flights; the 5 programmable LEDs are also a plus for use in dark or low-light conditions. The base includes a "trim wheel" and 15 action buttons, including numerous push buttons with resistance identical to that on a real airplane and industrial metal switches (2 or 3 positions) with highly realistic pressure.
Thrustmaster HOTAS Warthog - joystick and throttle - wired
Joystick and throttle
Wired
Dual throttle control, H.E.A.R.T HallEffect AccuRate Technology
PC
Wired
USB
2 x USB - 4 pin USB Type A
Software Included
32 cm
26 cm
44 cm
6.44 kg
PC
Type: Throttle
Type: Joystick
Compatibility: PC
Brand: Thrustmaster
Stock Status: While stocks last
Stock Status: Clearance
