Thrustmaster Flight Rudder Pedals
Quicklinx: D782WS00 Mfr#: 2960764
Type: Pedals
Wired / Wireless: Wired
Compatibility: PC, Sony PlayStation 4
40 In Stock
£82.50 ex VAT
£99.00 inc VAT
Thrustmaster TFRP Flight Rudder Pedals are compatible on PC with all joysticks on the market. They are also compatible on PS4 with the Flight Hotas 4 joystick (sold separately). This is the first rudder to feature the S.M.A.R.T slide rails system for smooth steering. Its ergonomic design allows you to put your entire foot on the pedal, thanks to the heel-rests. The heel-rests are removable, for alternative ergonomic configurations. You are able to place your entire foot on the pedal, or rest the ball of your foot at mid-pedal.
  • S.M.A.R.T
    Sliding Motion Advanced Rail Track slide rails system.
  • Perfectly smooth sliding motion
    Self-centering rudder axis: The perfect balance between smoothness and resistance for re-centering, for more accurate maneuvers. Long range of travel on rudder axis for precise maneuvers.
  • Two differential brake pedals for optimized flying
    Large differential brake pedals: 10 inches/25 centimeters (12/45 shoe size). Rounded central pivot with central grip, on the differential brake's axis. Pivot angle with a 15° range of travel: on an incline for deliberate activation, avoiding inadvertent activation when using the rudder.
  • Sturdiness and precision
    Versatile ergonomic design suitable for all types of flight (aerial combat, space adventure, civil flight, etc.). With the heel-rest removed, you can control the rudder using the ball of your foot, with your heel on the floor. With the heel-rest in place, you can rest 100% of your foot on the pedal.
Thrustmaster T-Flight Rudder Pedals - pedals - wired
Pedals
Wired
1-year warranty
Pedals
Wired
Gameport, USB
Microsoft Windows Vista / 7 / 8 / 10
USB - Gameport adapter
34.9 cm
31.4 cm
20.6 cm
2.21 kg
Limited warranty - 1 year
Type: Pedals
Compatibility: PC
Compatibility: Sony PlayStation 4
Brand: Thrustmaster
