DESIGNED FOR AN ULTIMATE PERFORMANCE IN MULTIPLAYER GAMES
Build. Swap. Program. Adjust. The precise, responsive and adaptable controller under official license PlayStation 4 for an optimized experience according to the type of game you’re playing. Designed to help you take your gaming to the next level, reach new heights of performance and achieve the best possible rankings.
ULTIMATE VERSATILITY
The ESWAP PRO CONTROLLER is the ultimate gamers weapon in search of an optimized experience for each type of game. The adjustable positioning of the modules on the controller — either right in the middle of a game, or when you’re not playing — lets adapt the right configuration for the best possible fit with players needs, or those of the team. The controller’s shape and ergonomics have been designed for a perfect fit with all gaming styles: combat, sports, FPS/TPS, battle royale and even RPG.
SURGICAL PRECISION
Flawless responsiveness — thanks to the tact switches incorporated into each module and button — is a must when it comes to boosting your chances of victory. Responsive clear clicks feeling mechanically increase the sensation of control, so gamers will never have to worry about response times while playing. Enjoy more than 5,000,000 activations on all buttons and more than 2,000,000 activations for the pre-calibrated ministicks.
UNLIMITED MODULAR ECOSYSTEM
The ESWAP PRO CONTROLLER features an unlimited modular ecosystem, at the crossroads of design and performance. A variety of packs incorporating new features — along with different color customization packs — are available, ensuring optimal comfort and eye-catching looks that fit in with every players’ favorite games. Try out new module textures, shapes and heights: you’ll love the different and complementary options available.
DESIGNED FOR THE RANKED
T-MOD modular technology and Hot-Swap feature, for effective in-game performance gives players the edge they need to react instantly in any situation, and improve their rankings. The controller’s sturdy braided cable allows for a stable, rock-solid wired connection and avoids any calibration problems, latency issues or inadvertent disconnection. Controller configuration via the included Thrustmapper software to adjust the different settings and sensitivity levels for the perfect fit.
THRUSTMAPPER SOFTWARE INCLUDED
Thrustmapper lets you master and adjust all essential settings: save 2 different presets for enhanced gaming ergonomics and optimized comfort, to meet your specific needs. Adjust the sensitivity, dead zones and vibration levels according to your preferences: give yourself a huge boost in your quest for gaming greatness.
REMAP BUTTONS
The software lets you assign the function of a button or a module to any other on the controller. Try out an infinite number of adjustments to find the best possible configuration.
CONFIGURE MINI-STICKS
Adjust the central and outer dead zones on both mini-sticks to best suit your gaming style. Set the overall sensitivity for each mini-stick according to your preferences.
CONFIGURE TRIGGERS
Configure the central and outer dead zones at both the beginning and end of the triggers’ range of travel for enhanced gaming precision.
ADJUST VIBRATION LEVELS
The intensity level of vibrations can be adjusted directly in the Thrustmapper software’s dedicated menu. Adjust the vibration intensity from 0 to 100% according to your preferences.
Improve your AIM
Specially designed to help perfect your aim, eSwap S Pro controller features next-generation (NXG) analog mini-sticks, for enhanced precision and an extended lifespan of 2 million activations. Whatever happens, you'll never be able to blame your gamepad - because it will never let you down! -
Master your diagonals
Dominate in fights and master all your diagonal movements, thanks to a D-pad with 4 tact switches for fantastic responsiveness. Link up all of your combos incredibly easily - thanks to an activation distance of just 0.02 inches/0.45 mm. -
Super-responsive buttons
You'll definitely want to take advantage of the super-responsive clicks made possible by the controller's tact switch buttons - which are 64% faster than standard membrane-based buttons and rated for more than 5 million activations. Response times are close to zero, with the buttons' activation distance reduced to 0.01 inches/0.3 mm. -
You decide
There's no need to learn how to adapt to this gamepad, because it can adapt to you instead. eSwap S Pro controller lets you adjust the physical travel of the triggers, along with their activation sensitivity. The controller easily adapts to your own personal preferences and gaming style! -
Your own gaming style
Customize the way that you play - thanks to two extremely handy additional buttons that can be configured directly via the gamepad itself, located on the back of eSwap S Pro controller. -
Fully customizable
Easily configure all eSwap S Pro controller settings: remap controls, set the sensitivity, tweak the dead zones, import and export gaming profiles, plus adjust the power of the vibrations.
- ThrustMaster eSwap S Pro - gamepad - wired
- Product Type
- Gamepad
- Connectivity Technology
- Wired
- Controls
- A button, B button, D-pad, X button, Y button, 2 mini-sticks, LB button, RB button
- Sensitivity adjustment, ergonomic non-slip trigger, 2 non-slip mini-sticks, adjustable vibration, detachable cable, adjustable dead zone, replaceable stick modules, T-MOD technology
- 2-year warranty
- Designed For
- PC, Microsoft Xbox One, Microsoft Xbox Series S, Microsoft Xbox Series X
- Product Type
- Gamepad
- Wired
- Controls
- Interface
- USB-C
- OS Required
- Windows 10
- Included Accessories
- 2 interchangeable mini-stick modules, USB-C cable (3 m)
- 16 cm
- 12 cm
- 6 cm
- 259 g
- Cable Length
- 3 m
- 2-year warranty
- Width (Shipping)
- 20.5 cm
- Depth (Shipping)
- 20 cm
- Height (Shipping)
- 8 cm
- Weight (Shipping)
- 666 g
- Designed For
