Thermaltake Core X9 E ATX Window
Quicklinx: B8PVWS00 Mfr#: CA-1D8-00F1WN-00
The Core X9, the first E-ATX chassis of the Core X Series by Thermaltake, is a cube case offering endless stackable capacity and expandability for enthusiasts to create massive liquid cooling systems, utilize as a file server as well as accommodate dual systems. Users can customize the chassis for the best viewing presentation with an interchangeable window and I/O panel design. The Core X9 delivers outstanding cooling performance with compatibility for extensive DIY/AIO LCS and overclocking components, further enhancing the reputation that the air-cooling units of this series has become renowned for. It is guaranteed to be an immensely powerful system!
  • Stackable for enthusiasts
    With its endless stacking design, the Core X9 is in a class above the rest. Virtually limitless utility is possible; it offers an expandable system allowing enthusiasts to incorporate externally-modular upgrades. Stacked together, the chassis opens up space to expand the liquid cooling system, the storage solutions, or even create dual systems, thereby enabling a dedicated top/bottom set-up for pure cooling. When stacked, the maximum radiator length supported is 600mm on the front side.
  • Remarkable expansion
    Designed for high-end gaming system compatibility, the Core X9's modular drive racks allow gamers to easily install up to six data storage devices, a dual expansion slot VGA of up to 590mm in length, and a tower CPU cooler as high as 250mm. Even with a high-wattage PSU stretching to 200mm in length, it still leaves plenty of space for cable management. Moreover, two 480mm radiators can be installed on top of the chassis, delivering superior cooling performance.
  • Excellent ventilation
    The Core X9's unparalleled cooling ability offers fan brackets with various mounting points to support any type of gaming system that can be accommodated, including DIY/AIO liquid-cooling systems and air-cooling units. A large 200mm fan is pre-installed on the front side and a rear 120mm fan reassures and guarantees the flow of aeration. The fan brackets can either be adjusted for 120mm, 140mm, or 200mm fans on the top panel, while there is room for 120mm and 140mm fans on the side panel.
  • Chambers concept
    Optimized for space management, the Core X9 is divided into two main chambers: the upper chamber is made for cooling performance and better efficiency, while the lower one is made for PSU and drive bays. Thanks to the removable 2.5"/3.5" drive device racks, there is plenty of flexibility to gain the maximum interior space when needed for advanced cooling performance or liquid systems build.
  • Fully modular design
    A "3 +9" drive bay concept design for storage devices makes setting up the best storage solution on the market super easy and flexible. In addition, a customizable 5.25" & 3.5" drive bay feature enables users to freely interchange the 3.5" hard-drive cages to suit their particular needs.
  • Interchangeable window and I/O panel
    Users can customize the chassis for the best viewing presentation with an interchangeable window and I/O panel design. Side I/O ports include four USB 3.0.
Thermaltake Core X9 - tower - extended ATX
System cabinet
Tower
Windowed Side Panel
I/O Connectors
4 x USB 3.0 , 1 x microphone , 1 x headphones/speakers
Supported Motherboards
ATX, microATX, Mini-ATX, Extended ATX
System Cabinet Features
Supports 120/140/240/280/360 mm radiator in front panel, supports 1/2", 3/8",1/4" water tube, stackable, supports 2 x 120/140/240/280/360/420/480 mm radiators in top, supports 120/140 mm radiator in rear, supports 120/140/240/280/360/420/480 mm radiator in side panel, supports 120/140/240/280/360/420/480 mm radiator in bottom
No power supply (PS/2)
50.2 cm x 38 cm x 64 cm
17 kg
Tower
Windowed Side Panel
Max Mainboard Size
Extended ATX
Internal Bays Qty
9
Front Accessible Bays Qty
3
Cooling System
Front: 200 x 200 x 30 mm fan x 1 / intake / 800 rpm / 13 dBA / 2 x 200 mm fan or 2 x 140 mm fan or 3 x 120 mm supported , Rear: 120 x 120 x 25 mm fan x 1 / exhaust / 1000 rpm / 16 dBA / TurboFan, 2 x 120/140 mm fan supported , Top: 120 mm fan mount x 8 / 6 x 140 mm or 2 x 200 mm fan supported , Bottom: 120 mm fan mount x 3 , Side: 140 mm fan mount x 3 / 4 x 120 mm fan supported
CPU Cooler Max Height
250 mm
Video Card Max Length
400 mm
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 6 (total) / 6 (free) x internal - 2.5" / 3.5" shared , 1 (total) / 1 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
8
4 x USB 3.0 , 1 x microphone - mini-jack , 1 x headphones/speakers - mini-jack
No power supply
Specification Compliance
PS/2
50.2 cm
38 cm
64 cm
17 kg
