The Techair Attaché is a slimline contemporary case specifically designed to carry and protect Ultrabooks. Your Ultrabook is safely secured in the fur lined laptop compartment providing soft abrashion free protection. An additional pocket provides space for accessories and power supply.
The Techair Attaché is a slimline contemporary case specifically designed to carry and protect Ultrabooks and other slim 12"-13.3" laptops. When on the move your Ultrabook is safely secured in the fur lined laptop compartment providing soft abrasion free protection. An additional pocket provides space for accessories and power supply. The luxury webbing handles and shoulder strap plus the durable material all add up to making a great light weight product that will compliment your UltraBook.
- techair Ultrabook Laptop Bag - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- Polyester
- 34.5 cm x 4 cm x 23.5 cm
- 360 g
- Notebook Compatibility
- 13.3"
- Notebook Supported Sizes
- 12" - 13.3" / 30.5 cm - 33.8 cm
- Zipper pockets, faux fur inner lining, premium webbing shoulder strap protective foam
- Carrying Strap
- Hand strap, adjustable shoulder strap
- Limited lifetime warranty
- Product Type
- Product Material
- Polyester
- 34.5 cm
- 4 cm
- 23.5 cm
- 360 g
- 13.3"
- Notebook Compatibility Dimensions
- 33 cm x 23 cm x 2.5 cm
- Carrying Strap
- Closure Type
- Zipper pocket
- Compartments Quantity
- 2
- Black
- Protective foam
- Limited warranty: - lifetime
