Techair Slipcase Black 14.1"
Quicklinx: DPP0WS00 Mfr#: TANZ0309V4
Type: Bags & Cases
More than 50 in stock
£8.41 ex VAT
£10.09 inc VAT
If you need a sleeve that gives you a little more than just function, then the neoprene sleeve fits perfectly. With a contrasting yellow, faux fur inner it gives you a little bit of cheekiness as you unzip the black outer. Your laptop is happily protected, easily fits into other bags, or you can show it off solo. Now that’s function with emotion.
Tech air Z Series Z0309V4 notebook sleeve
Notebook sleeve
Product Material
Neoprene, textured polyester
35 cm x 2.5 cm x 26 cm
217.3 g
Notebook Compatibility
14.1"
Notebook Supported Sizes
12" - 14.1" / 30.5 cm - 35.8 cm
Notebook sleeve
Product Material
35 cm
2.5 cm
26 cm
217.3 g
14.1"
Notebook Compatibility Dimensions
34.2 cm x 25.2 cm x 2 cm
Closure Type
Zipper
Lining Material
Faux fur
Limited warranty - lifetime
Techair Slipcase Black 14.1 Bundle deal on Techair Slipcase Black 14.1"
£107.58
Type: Bags & Cases
Brand: Techair
Price Range Ex VAT: 0 - 50
