Techair Slipcase Black 14.1"
Quicklinx: DPP0WS00 Mfr#: TANZ0309V4
Device Type: Notebook
Type: Sleeve
Device Screen Size: 14.1
Colour: Black
More than 50 In Stock
£9.44 ex VAT
£11.32 inc VAT
If you need a sleeve that gives you a little more than just function, then the neoprene sleeve fits perfectly. With a contrasting yellow, faux fur inner it gives you a little bit of cheekiness as you unzip the black outer. Your laptop is happily protected, easily fits into other bags, or you can show it off solo. Now that’s function with emotion.
  • Enhanced protection
    Crafted with a combination of neoprene and textured polyester, this notebook sleeve offers protection against bumps and scratches, ensuring your device remains in pristine condition.
  • Soft interior
    The interior is lined with faux fur, providing a soft cushion that keeps your notebook safe from scratches while adding an extra layer of protection.
  • Convenient compatibility
    Designed to accommodate notebooks from 12" to 14.1", this sleeve ensures a snug fit for a wide range of devices, making it a versatile choice for protecting your technology.
Tech air Z Series Z0309V4 - notebook sleeve
Notebook sleeve
Product Material
Neoprene, textured polyester
35 cm x 2.5 cm x 26 cm
217.3 g
Notebook Compatibility
14.1"
Notebook Supported Sizes
12" - 14.1" / 30.5 cm - 35.8 cm
Notebook sleeve
Product Material
35 cm
2.5 cm
26 cm
217.3 g
14.1"
Notebook Compatibility Dimensions
34.2 cm x 25.2 cm x 2 cm
Closure Type
Zipper
Lining Material
Faux fur
Limited warranty: - lifetime
Type: Sleeve
Colour: Black
Brand: Techair
