Techair Series 5 5902 - Notebook carrying case - grey, blue
Quicklinx: 49Z8WS00 Mfr#: TAN5902
The weekender is an essential trolley bag for any overnight travel. Extremely practical and with plenty of well-thought accessories, the weekender cuts the need of taking 2 bags for a weekend away. Compact and high capacity, this trolley is a great travel partner. The rolling design takes the strain of travel whilst the fresh colors and soft lines makes carrying your laptop inconspicuous. Laptop compartment designed to accommodate laptops up to 15.4".
Includes TechAir Protection Technology - lining the base and sides of your laptop are interconnecting tubes of compressed air. On contact, the shock is absorbed and dissipated away by the aircells from the point of impact, cushioning your laptop from the blow.
Includes 12 months i-TRAK service - i-TRAK is an exclusive world-wide lost property solution which gives your bag and laptop a unique identity so they can be traced back to you.
Tech air Series 5 5902 - notebook carrying case
Grey, blue
Product Material
Polyester
54 cm x 36.5 cm x 16.5 cm
2.7 kg
Notebook Compatibility
15.4"
I-TRAK 12 months, Active Sleeve, TechAir Protection Technology, Wet Skinn
Telescopic Handle / Wheels
Product Material
Polyester
54 cm
36.5 cm
16.5 cm
2.7 kg
15.4"
Notebook Compatibility Dimensions
36.5 cm x 29.3 cm x 5.1 cm
Additional Compartments
Mobile phone, credit cards, documents, pens, MP3 player, tickets
Grey, blue
Limited warranty: - lifetime
