This all round protective cover (for Samsung Tab A 10.1") is perfect for those that play rough and want reliable protection. The combination of rigid plastic and shock absorbing silicone ensures your machine is always protected while the built in screen cover keeps your touchscreen protected and scratch free. With an incorporated stand and full access to buttons and power this cover is hard to beat.
- techair - protective case for tablet
- Product Type
- Protective case for tablet
- Screen Size Compatibility
- 10.1"
- 25 cm x 16 cm x 2 cm
- 310 g
- Material
- Silicone, polycarbonate
- Black
- Limited lifetime warranty
- Designed For
- Samsung Galaxy Tab A (2019) (10.1 in)
- 25 cm
- 16 cm
- 2 cm
- 310 g
- Rugged
- Material
- Black
Carrying Case
- Protective case
- Recommended Use
- For tablet
- 10.1"
- Protection
- Shockproof
- Inner Dimensions
- 24.5 cm x 14.9 cm x 0.8 cm
- Cover Features
- Stand function
- Lifetime
- Designed For
