Techair iPad 9.7" Rugged Case
Quicklinx: DQ4NWS00 Mfr#: TAXIPF042
This all round protective cover is perfect for those that play rough and want reliable protection. The combination of rigid plastic and shock absorbing silicone ensures your machine is always protected while the built-in screen cover keeps your touchscreen protected and scratch free. With an incorporated stand and full access to buttons and power this cover is hard to beat. Now that's function with emotion.
techair - protective case for tablet
Protective case for tablet
Screen Size Compatibility
9.7"
19.2 cm x 2 cm x 26.3 cm
350 g
Material
Silicone, polycarbonate
Apple 9.7-inch iPad (5th generation, 6th generation)
19.2 cm
2 cm
26.3 cm
350 g
Rugged
Material
Carrying Case
Protective case
Recommended Use
For tablet
9.7"
Protection
Shockproof, scratch-resistant
Inner Dimensions
16.95 cm x 0.75 cm x 24 cm
Cover Features
Stand function
Lifetime
