This all round protective cover (for iPad 10.2) is perfect for those that play rough and want reliable protection. The combination of rigid plastic and shock absorbing silicone ensures your machine is always protected while the built in screen cover keeps your touchscreen protected and scratch free. With an incorporated stand and full access to buttons and power this cover is hard to beat.
Rotating kickstand
The rugged tablet case comes with a 360-degree kickstand, which allows for multiple viewing positions. -
Built-in screen protector
The built-in screen protector keeps your touchscreen scratch free and protected. -
Shock-absorbing silicone exterior
The combination of rigid plastic and shock-absorbing silicone ensures your machine is always protected.
- techair classic pro - protective case for tablet
- Product Type
- Protective case for tablet
- Screen Size Compatibility
- 10.2"
- 19.3 cm x 2.3 cm x 26.1 cm
- 390 g
- Material
- Silicone, polycarbonate
- Black
- Limited lifetime warranty
- Designed For
- Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation)
- 19.3 cm
- 2.3 cm
- 26.1 cm
- 390 g
- Rugged
- Material
- Black
Carrying Case
- Protective case
- Recommended Use
- For tablet
- 10.2"
- Protection
- Scratch-resistant, shock-resistant
- Additional Compartments
- Stylus
- Inner Dimensions
- 17.4 cm x 0.8 cm x 25.1 cm
- Built-in screen protector, 360-degree rotation
- Cover Features
- Stand function
- Lifetime
- Designed For
