Techair Essential USB Mouse
Quicklinx: GJD9WS00 Mfr#: XM301Bv2
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wired
Colour: Grey
Compatibility: PC
£4.88 ex VAT
£5.85 inc VAT
The techair USB notebook mouse. Simply plug in and play (no software needed). Compact, lightweight and easy to use. That’s function with emotion!
  • Efficient movement detection
    The optical technology employed in this mouse ensures smooth and accurate tracking, making it suitable for various surface types while responding effectively to user gestures.
  • Flexible cable length
    With a 2 m cable length, this mouse offers ample reach, allowing users to connect comfortably without feeling restricted by short cables.
  • Quick setup
    The Plug-and-Play compliance enables immediate use without the need for complicated installation processes, ensuring a user-friendly experience from the moment it is connected.
techair XM301Bv2 - mouse - USB - grey
Mouse
Wired - USB
Grey
5.5 cm x 9.7 cm x 3.4 cm
80 g
Movement Detection Technology
Optical
Movement Resolution
1000 dpi
Scrolling wheel
Cable Length
2 m
Mouse
5.5 cm
9.7 cm
3.4 cm
80 g
Grey
Input Device
Wired
USB
Optical
Movement Resolution
1000 dpi
Cable Length
2 m
Scrolling wheel
1 x USB - 4 pin USB Type A
Plug and Play
Type: Mouse
Colour: Grey
Compatibility: PC
Brand: Techair
