Keep your technology secure and reduce the chance of theft with this clever and sturdy combination security lock. Designed for devices that feature the traditional T Bar style security slot. Easy to engage and remove.
Durable construction
Constructed from high-strength steel, this security cable lock is designed for long-lasting durability and resistance to tampering, providing peace of mind for the user. -
Customizable security
The combination lock functionality allows users to set their own 4 digit code, offering flexibility and control over access while minimizing the risk of forgotten keys. -
Enhanced safety
With a robust T-bar lock feature, this cable lock provides a secure connection that is less susceptible to manipulation and forced entry, ensuring belongings remain safe. -
Surface protection
Thanks to its vinyl-coated exterior, the lock safeguards surfaces from scratches and damage while providing a comfortable grip for users during operation.
- techair - security cable lock
- Product Type
- Security cable lock
- Silver
- Product Material
- Steel
- Length
- 2 m
- 160 g
- Combination lock, T- bar lock, 4 digit code, vinyl-coated
- 2-year warranty
- Product Type
- Product Material
- Steel
- Length
- 2 m
- 160 g
- Silver
- Limited warranty: - 2 years
