This protective case (for Surface Pro 9) is perfect for those working while on the move. The combination of rigid plastic and shock absorbing silicone provides unbeatable protection. With a clever way of incorporating the use of the built in stand and full access to buttons and power this cover is hard to beat.
Durable construction
The case is made with a combination of polycarbonate and thermoplastic polyurethane, providing strong protection against everyday wear and tear. -
Versatile kickstand
The multi-position kickstand allows users to adjust the angle, providing options for both portrait and landscape viewing. -
Stylus holder included
A dedicated stylus holder ensures that users can easily store and access their stylus whenever needed. -
Rugged protection
Designed to be shock absorbent, this case safeguards the tablet against impacts, making it reliable for various environments. -
Accommodates keyboard usage
The design of the case facilitates the use of a keyboard, enhancing productivity and functionality for users.
- techair - back cover for tablet
- Product Type
- Back cover for tablet
- 21.5 cm x 3 cm x 29.5 cm
- 400 g
- Material
- Polycarbonate, thermoplastic polyurethane (TPU)
- 3-year warranty
- Designed For
- Microsoft Surface Pro 9
- 21.5 cm
- 3 cm
- 29.5 cm
- 400 g
- Rugged
- Material
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Protection
- Shock-absorbent
- Cover Type
- Back cover
- Additional Compartments
- Stylus holder
- Inner Dimensions
- 20.9 cm x 0.9 cm x 28.7 cm
- Accommodates use of keyboard, multi-position stand, shock absorbing structure
- Cover Features
- Kickstand for portrait or landscape viewing
- Limited warranty - 3 years
- Designed For
- Microsoft Surface Pro 9, Pro 9 for Business
Techair Classic Pro Surface Pro 9, 10 & 11 Rugged Case
