If you’re looking for complete all round protection then look no further than protective hard shell from techair. This tough fully protective wrap around hard shell not only provides protection from bumps and knocks, it helps keep your Lenovo 100e/100w Chromebook 3rd Gen (Clamshell free from marks and scratches without compromising access to ports, buttons and speakers. Made from rigid PC + TPU material the product has the added benefit of being ultralight and ergonomic whilst offering supreme protection.
- techair Classic pro - notebook shell case - form fitting
- Product Type
- Notebook shell case - form fitting
- Clear
- Product Material
- Polycarbonate, thermoplastic polyurethane (TPU)
- 31.3 cm x 3 cm x 21.7 cm
- 320 g
- Corner impact protection, lightweight design, non-slip feet, ergonomic drop-resistant, scratch-resistant, bumper protection
- Limited lifetime warranty
- Designed For
- Lenovo 100e Chromebook Gen 3
- Product Type
- Product Material
- 31.3 cm
- 3 cm
- 21.7 cm
- 320 g
- Shipping Dimensions (WxDxH) / Weight
- 340 g
- Notebook Compatibility Dimensions
- 29 cm x 2 cm x 20.2 cm
- Clear
- Drop-resistant, scratch-resistant, bumper protection
- Limited warranty: - lifetime
- Designed For
