Techair Classic Pro Lenovo 100E/100W Chromebook 3rd Gen Hard Shell
Quicklinx: H2TDWS00 Mfr#: TACHS002
If you’re looking for complete all round protection then look no further than protective hard shell from techair. This tough fully protective wrap around hard shell not only provides protection from bumps and knocks, it helps keep your Lenovo 100e/100w Chromebook 3rd Gen (Clamshell free from marks and scratches without compromising access to ports, buttons and speakers. Made from rigid PC + TPU material the product has the added benefit of being ultralight and ergonomic whilst offering supreme protection.
techair Classic pro - notebook shell case - form fitting
Notebook shell case - form fitting
Clear
Product Material
Polycarbonate, thermoplastic polyurethane (TPU)
31.3 cm x 3 cm x 21.7 cm
320 g
Corner impact protection, lightweight design, non-slip feet, ergonomic drop-resistant, scratch-resistant, bumper protection
Lenovo 100e Chromebook Gen 3
Product Material
31.3 cm
3 cm
21.7 cm
320 g
340 g
Notebook Compatibility Dimensions
29 cm x 2 cm x 20.2 cm
Clear
Drop-resistant, scratch-resistant, bumper protection
Limited warranty: - lifetime
