Techair Classic Pro Lenovo 100E/100W Chromebook 3rd Gen Hard Shell
Quicklinx: H2TDWS00 Mfr#: TACHS002
Device Type: Chromebook
Type: Case
Device Screen Size: 11.6
Colour: Black, Clear
Sorry but this product has been discontinued.
View used stock
If you’re looking for complete all round protection then look no further than protective hard shell from techair. This tough fully protective wrap around hard shell not only provides protection from bumps and knocks, it helps keep your Lenovo 100e/100w Chromebook 3rd Gen (Clamshell free from marks and scratches without compromising access to ports, buttons and speakers. Made from rigid PC + TPU material the product has the added benefit of being ultralight and ergonomic whilst offering supreme protection.
techair Classic pro - notebook shell case - form fitting
Notebook shell case - form fitting
Clear
Product Material
Polycarbonate, thermoplastic polyurethane (TPU)
31.3 cm x 3 cm x 21.7 cm
320 g
Corner impact protection, lightweight design, non-slip feet, ergonomic drop-resistant, scratch-resistant, bumper protection
Lenovo 100e Chromebook Gen 3
Product Material
31.3 cm
3 cm
21.7 cm
320 g
340 g
Notebook Compatibility Dimensions
29 cm x 2 cm x 20.2 cm
Clear
Drop-resistant, scratch-resistant, bumper protection
Limited warranty: - lifetime
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: H2TD 049150
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £3.54
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Case
Colour: Black
Colour: Clear
Brand: Techair
Stock Status: Used Stock
Stock Status: Clearance
