The techair TALUC07 security cable lock offers protection for your valuables. Constructed from durable steel, this lock is designed to withstand tampering, while its vinyl-coated finish adds an extra layer of security and prevents damage to your gear. With a 4-digit combination code, users can easily set their personalized security level, ensuring their items remain safe. The wedge lock slot design enhances versatility, allowing for easy attachment to a variety of items, making it a choice for anyone seeking dependable protection.
Strong and durable material
Made from steel, this security cable lock provides a defense against potential threats, ensuring long-lasting reliability. -
Flexible combination security
The 4-digit code allows users to set a unique combination, making it hard for intruders to access secured items. -
Protective vinyl coating
The vinyl-coated exterior offers a grip and protects surfaces from scratches and damage. -
Versatile locking slot
Features a wedge lock slot that enables attachment to various objects, enhancing usability across different scenarios.
- techair - security cable lock
- Product Type
- Security cable lock
- Silver
- Product Material
- Steel
- 0.45 cm
- Length
- 2 m
- 138 g
- Combination lock, 4 digit code, vinyl-coated, wedge lock slot
- 3-year warranty
- Product Type
- Product Material
- Steel
- 0.45 cm
- Length
- 2 m
- 138 g
- Silver
- Limited warranty: - 3 years
