You've got a hectic schedule and we've got the perfect bag for your 14.1" notebook. It's got foam protection for all those little bumps and knocks on the way, it's lightweight and compact and its got classic good looks. What more can you ask for to function with emotion? Well, don't forget the lifetime warranty.
- techair Classic - notebook carrying case
- Product Type
- Notebook carrying case
- Grey
- Product Material
- Textured polyester
- 38 cm x 6.5 cm x 28 cm
- 492.5 g
- Notebook Compatibility
- 14.1"
- Notebook Supported Sizes
- 12" - 14.1" / 30.5 cm - 35.8 cm
- Foam padding
- Carrying Strap
- Padded top handle, removable shoulder strap, adjustable shoulder strap
- Limited lifetime warranty
- Product Type
- Product Material
- 38 cm
- 6.5 cm
- 28 cm
- 492.5 g
- 14.1"
- Notebook Compatibility Dimensions
- 34.2 cm x 25.2 cm x 4 cm
- Additional Compartments
- Front external zipped pocket
- Foam padding
- Carrying Strap
- Closure Type
- Zipper
- Compartments Quantity
- 1
- Grey
- Limited warranty - lifetime
