Techair Classic Clam Grey 14.1"
Quicklinx: FHVQWS00 Mfr#: TANZ0136
You've got a hectic schedule and we've got the perfect bag for your 14.1" notebook. It's got foam protection for all those little bumps and knocks on the way, it's lightweight and compact and its got classic good looks. What more can you ask for to function with emotion? Well, don't forget the lifetime warranty.
  • Enhanced Durability
    Crafted from textured polyester, this notebook carrying case offers enhanced durability against daily wear and tear, ensuring your device remains protected in various conditions.
  • Comfortable Portability
    Featuring an adjustable shoulder strap, padded top handle, and a removable shoulder strap, this carrying case provides versatile carrying options to suit your comfort and lifestyle needs.
  • Organized Storage
    With a front external zipped pocket alongside the main compartment, it allows for organized storage of your notebook and essential accessories, keeping everything you need within easy reach.
techair Classic - notebook carrying case
Notebook carrying case
Grey
Product Material
Textured polyester
38 cm x 6.5 cm x 28 cm
492.5 g
Notebook Compatibility
14.1"
Notebook Supported Sizes
12" - 14.1" / 30.5 cm - 35.8 cm
Foam padding
Carrying Strap
Padded top handle, removable shoulder strap, adjustable shoulder strap
Product Material
Textured polyester
38 cm
6.5 cm
28 cm
492.5 g
14.1"
Notebook Compatibility Dimensions
34.2 cm x 25.2 cm x 4 cm
Additional Compartments
Front external zipped pocket
Foam padding
Carrying Strap
Closure Type
Zipper
Compartments Quantity
1
Grey
Limited warranty: - lifetime
