You've got a hectic schedule and we've got the perfect bag for your 14.1" notebook. It's got foam protection for all those little bumps and knocks on the way, it's lightweight and compact and its got classic good looks. What more can you ask for to function with emotion? Well, don't forget the lifetime warranty.
Enhanced Durability
Crafted from textured polyester, this notebook carrying case offers enhanced durability against daily wear and tear, ensuring your device remains protected in various conditions. -
Comfortable Portability
Featuring an adjustable shoulder strap, padded top handle, and a removable shoulder strap, this carrying case provides versatile carrying options to suit your comfort and lifestyle needs. -
Organized Storage
With a front external zipped pocket alongside the main compartment, it allows for organized storage of your notebook and essential accessories, keeping everything you need within easy reach.
- techair Classic - notebook carrying case
- Product Type
- Notebook carrying case
- Grey
- Product Material
- Textured polyester
- 38 cm x 6.5 cm x 28 cm
- 492.5 g
- Notebook Compatibility
- 14.1"
- Notebook Supported Sizes
- 12" - 14.1" / 30.5 cm - 35.8 cm
- Foam padding
- Carrying Strap
- Padded top handle, removable shoulder strap, adjustable shoulder strap
- Limited lifetime warranty
- Product Type
- Product Material
- 38 cm
- 6.5 cm
- 28 cm
- 492.5 g
- 14.1"
- Notebook Compatibility Dimensions
- 34.2 cm x 25.2 cm x 4 cm
- Additional Compartments
- Front external zipped pocket
- Foam padding
- Carrying Strap
- Closure Type
- Zipper
- Compartments Quantity
- 1
- Grey
- Limited warranty: - lifetime
