You've got a hectic schedule and we've got the perfect bag for your notebook. It's got foam protection for all those little bumps and knocks on the way, it's lightweight and compact and it's got classic good looks. What more can you ask for to function with emotion? Well, don't forget the lifetime warranty.
Main Features:
- Lightweight and compact
- Foam protection
- Removable and adjustable shoulder strap
- Additional pockets for accessories
- Black
- Lifetime warranty
Durable design
Crafted from 600D polyester, this notebook carrying case offers robust protection against daily wear and tear, ensuring your device remains safeguarded during commutes and travel. -
Versatile carrying options
Equipped with an adjustable shoulder strap, a removable option, and a top carry handle, this case provides multiple carrying methods to suit your comfort and needs. -
Optimized organization
Featuring additional compartments for notebook accessories, it allows for efficient organization and easy access to your essentials, keeping everything you need in one place.
- techair - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- 600D polyester
- 33.5 cm x 6.5 cm x 24 cm
- 606 g
- Notebook Compatibility
- 11.6"
- Carrying Strap
- Top carry handle, removable shoulder strap, adjustable shoulder strap
- Limited lifetime warranty
- Product Type
- Product Material
- 600D polyester
- 33.5 cm
- 6.5 cm
- 24 cm
- 606 g
- 11.6"
- Notebook Compatibility Dimensions
- 30.5 cm x 21 cm x 3 cm
- Additional Compartments
- Notebook accessories
- Carrying Strap
- Lining Material
- Foam
- Black
- Limited warranty: - lifetime
Techair Clamshell Briefcase for 11.6" Laptops - Black
