Simple, classic & lightweight with some extra protection for your laptop via the foam cushioned compartment. All this plus extra storage for documents and other stuff, make this a perfect way to function with emotion.
Enhanced durability
Crafted from high-quality polyester, this notebook carrying backpack is designed to withstand the rigors of daily use, ensuring your device stays protected wherever you go. -
Comfortable carrying
Featuring an adjustable shoulder strap and foam padding, the backpack offers superior comfort and support, making it easier to carry your notebook throughout the day without strain. -
Spacious design
With two compartments, this backpack provides ample space for a 15.6-inch notebook along with other essentials, ensuring everything you need is always within reach.
- Tech air Series 1 1713 - notebook carrying backpack
- Product Type
- Notebook carrying backpack
- Textured blue
- Product Material
- Polyester
- 41.5 cm x 12 cm x 39 cm
- 512 g
- Notebook Compatibility
- 15.6"
- Foam padding, adjustable shoulder strap
- Limited lifetime warranty
- Product Type
- Product Material
- Polyester
- 41.5 cm
- 12 cm
- 39 cm
- 512 g
- 15.6"
- Notebook Compatibility Dimensions
- 31.7 cm x 27 cm x 4 cm
- Compartments Quantity
- 2
- Textured blue
- Limited warranty: - lifetime
Techair Backpack Blue 15.6"
