Techair Backpack Blue 15.6"
Quicklinx: FHVXWS00 Mfr#: TAN1713
Device Type: Laptop
Type: Backpack
Device Screen Size: 15.6
Colour: Blue
Hurry, only 2 left in stock!
£16.67 ex VAT
£20.00 inc VAT
Simple, classic & lightweight with some extra protection for your laptop via the foam cushioned compartment. All this plus extra storage for documents and other stuff, make this a perfect way to function with emotion.
  • Enhanced durability
    Crafted from high-quality polyester, this notebook carrying backpack is designed to withstand the rigors of daily use, ensuring your device stays protected wherever you go.
  • Comfortable carrying
    Featuring an adjustable shoulder strap and foam padding, the backpack offers superior comfort and support, making it easier to carry your notebook throughout the day without strain.
  • Spacious design
    With two compartments, this backpack provides ample space for a 15.6-inch notebook along with other essentials, ensuring everything you need is always within reach.
Tech air Series 1 1713 - notebook carrying backpack
Notebook carrying backpack
Textured blue
Product Material
Polyester
41.5 cm x 12 cm x 39 cm
512 g
Notebook Compatibility
15.6"
Foam padding, adjustable shoulder strap
Product Material
Polyester
41.5 cm
12 cm
39 cm
512 g
15.6"
Notebook Compatibility Dimensions
31.7 cm x 27 cm x 4 cm
Compartments Quantity
2
Textured blue
Limited warranty: - lifetime
Device Type: Laptop
Type: Backpack
Colour: Blue
Brand: Techair
