This sleek top loader with foam protection for your laptop offers plenty of space for your documents and accessories and a comfy shoulder strap.
Durable construction
Crafted from 600D polyester, this carrying case provides robust protection and durability, making it suitable for everyday use. -
Comfortable carrying
The adjustable and removable shoulder strap ensures flexibility and comfort while carrying, reducing strain on the shoulders during transit. -
Secure storage
The zipper closure allows for easy access to the contents while keeping the notebook safely enclosed during travel. -
Protective lining
A foam lining within the case adds an extra layer of protection against shocks, ensuring the notebook remains safe from scratches and impacts. -
Spacious design
Designed to accommodate notebooks with dimensions up to 43.9 cm in width and 4.5 cm in height, offering ample space for other accessories.
- techair - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- 600D polyester
- 46 cm x 33 cm x 6.5 cm
- 750 g
- Notebook Compatibility
- 17.3"
- Notebook Supported Sizes
- 16" - 17.3" / 40.6 cm - 43.9 cm
- Removable shoulder strap, adjustable shoulder strap
- Carrying Strap
- Shoulder carrying strap
- Limited lifetime warranty
- Product Type
- Product Material
- 600D polyester
- 46 cm
- 33 cm
- 6.5 cm
- 750 g
- 17.3"
- Notebook Compatibility Dimensions
- 42 cm x 30 cm x 4.5 cm
- Carrying Strap
- Closure Type
- Zipper
- Lining Material
- Foam
- Black
- Limited warranty: - lifetime
