Want to keep it casual? Then look no further than the Evo messenger. This bag has tons of space to carry everything you need. Take a look at the nifty magnetic pocket that can be quickly removed and replaced. Soft faux-fur lining keeps your laptop snug and the nifty side access pocket means you can get to it quickly too. That's what function with emotion is all about.
- techair EVO Magnetic Laptop Messenger notebook carrying case
- Product Type
- Notebook carrying case
- Grey texturised
- Product Material
- Textured polyester
- 40.5 cm x 8 cm x 31 cm
- 1.044 kg
- Notebook Compatibility
- 15.6"
- Faux fur inner lining, removable magnetic pockets
- Carrying Strap
- Adjustable shoulder strap
- Limited lifetime warranty
- Product Type
- Product Material
- 40.5 cm
- 8 cm
- 31 cm
- 1.044 kg
- 15.6"
- Notebook Compatibility Dimensions
- 38.5 cm x 26.5 cm x 2.2 cm
- Carrying Strap
- Closure Type
- Zipper, zipper pocket
- Lining Material
- Foam, faux fur
- Grey texturised
- Limited warranty - lifetime
