Techair 15.6" Black Slip Case With Yellow Lining
Quicklinx: C32NWS00 Mfr#: TANZ0306v3
Device Type: Laptop
Type: Case
Device Screen Size: 15.6
Colour: Black
14 In Stock
£10.39 ex VAT
£12.46 inc VAT
If you need a sleeve that gives you a little more than just function, then the neoprene sleeve fits perfectly. With a faux fur inner it gives you a little bit of cheekiness as you unzip the outer. Your laptop is happily protected, easily fits into other bags, or you can show it off solo.
  • Durable design
    Crafted from neoprene and textured polyester, this notebook sleeve offers a robust shield against daily wear and tear, ensuring your device remains protected in various conditions.
  • Soft interior
    The faux fur lining provides a soft bed for your notebook, reducing the risk of scratches and impacts during transportation.
  • Convenient compatibility
    Designed to accommodate notebooks up to 15.6 inches, this sleeve ensures a snug fit for a wide range of PC models, making it a versatile choice for many users.
techair - notebook sleeve
Notebook sleeve
Product Material
Neoprene, textured polyester
38 cm x 2 cm x 27.5 cm
200 g
Notebook Compatibility
15.6"
Notebook sleeve
Product Material
38 cm
2 cm
27.5 cm
200 g
15.6"
Notebook Compatibility Dimensions
39 cm x 27 cm x 4 cm
Closure Type
Zipper
Lining Material
Faux fur
Limited warranty - lifetime
Device Type: Laptop
Type: Case
Colour: Black
Brand: Techair
