Techair 14-15.6" Classic Laptop Bag
Quicklinx: GJCMWS00 Mfr#: TANZ0142
Device Type: Laptop
Type: Case
Device Screen Size: 14 - 15.6
Colour: Black
Hurry, only 3 left in stock!
£12.02 ex VAT
£14.42 inc VAT
You’ve got a hectic schedule and we’ve got the perfect bag for your notebook. It’s got foam protection for all those little bumps and knocks on the way, it’s lightweight and compact and its got classic good looks. What more can you ask for to function with emotion? Well, don’t forget the lifetime warranty.
  • Durable construction
    Made from robust 600D polyester, this carrying case is built to withstand wear and tear, ensuring use.
  • Versatile carrying options
    Equipped with both a removable and adjustable shoulder strap, this case adapts to your carrying preferences, enhancing comfort during transport.
  • Secure closure
    The zipper closure ensures that your notebook is securely housed, preventing accidental openings.
  • Optimized protection
    With a foam lining, this carrying case offers protection against impacts, keeping your device safe from bumps and scratches.
  • Compatibility with multiple sizes
    This case supports notebooks ranging from 14 inches to 15.6 inches, making it suitable for various laptop models.
techair - notebook carrying case
Notebook carrying case
Product Material
600D polyester
42 cm x 29.5 cm x 6 cm
690 g
Notebook Compatibility
15.6"
Notebook Supported Sizes
14" - 15.6" / 35.6 cm - 39.6 cm
Removable shoulder strap, adjustable shoulder strap
Carrying Strap
Shoulder carrying strap
Product Material
600D polyester
42 cm
29.5 cm
6 cm
690 g
15.6"
Notebook Compatibility Dimensions
39 cm x 27 cm x 4 cm
Carrying Strap
Closure Type
Zipper
Lining Material
Foam
Limited warranty: - lifetime
Device Type: Laptop
Type: Case
Colour: Black
Brand: Techair
